Page 1 of 2
ICW from Chesapeake Bay to florida
Posted: Wed Jan 06, 2021 8:26 pm
by jlh3rd
Hello,
I'll get right to it .....Would you take a 2007, 24', twin 25" tubes, 60hp pontoon from the north end of the chesapeake on the ICW to Florida? If no, could the reason/reasons be fixed? This would be in conjunction with a 38' sailboat. Maybe wives , maybe solo. Ive only operated on rivers and lakes.
I like adventure, but with age comes wisdom.
Re: ICW from Chesapeake Bay to florida
Posted: Fri Jan 08, 2021 6:57 am
by wwind3
do it!
Take xtra prop(s) and xtra gas. Maybe a boat cover you can get under if weather goes crazy on you. Check your cellphone carrier for coverage as you travel. Portable battery charger and maybe an inverter. Xtra NEW boat battery. Plenty of water, sleeping bags, toiletries, etc. Grill, fishing equipment.
There are publications I think that may be helpful as to whether there are places along the way that cater to the folks doing this.
Jealous!!!!!
You may need a bigger boat and motor
Posted: Fri Jan 08, 2021 7:18 am
by TWB
The thought of this type of cruise piqued my interest, so I did a little looking around. I found this info. It doesn't address ALL of the things I was hoping (general weather trends mostly), but it does seem to give some good points for consideration.
https://www.offshoreblue.com/cruise/aicw-intro.php
Gonna keep watching this thread to see how it progresses.
Good Luck in your planning. Please update as you make decisions.
-Paul
Posted: Fri Jan 08, 2021 7:42 pm
by rbtnt
You might find some info here.
https://www.greatloop.org/
Posted: Sat Jan 09, 2021 3:08 pm
by jlh3rd
I will read those articles. A little added background. I have been investigating this for months. There are some reputable people that have said no because of the sounds and bays that are notorious for waves, big boats with careless operators and waves, coupled with a pontoon's " diving" characteristics. As a retired airline pilot,( no, I'm not one of the rich ones) I balance adventure, risk, opinions, facts, experience ( or lack of) with....I wanna do this....
I am looking at a possible engine up grade, minimum 90hp, max 110. The boat is equipped with a full enclosure of which I have engineered to be secured with straps and snaps to the full bimini top ( except for the stern piece) so access is a simple matter of unsnapping the straps and rolling them down. There is a porta potty installed. I would carry an inflatable mattress, a mini generator, and an electric heater if forced to sleep on the boat as a backup. The sailboat does have two rooms....but you never know what might happen. I have the normal boat requirements such as first aid, tools, spare parts, two-way, etc. My friend with the sailboat has never done the ICW either......I know planning is paramount as to accommodations and food, but I'd hope to play that by ear....as I used to do on my motorcycle trips out west...Cell phones and GPS were great for that....
.....This is just the investigation stage....appreciate all info....
Posted: Sat Jan 09, 2021 3:32 pm
by wwind3
definitely do the engine upgrade--always try to run rated HP. Good luck...
Posted: Sun Jan 10, 2021 6:43 am
by jlh3rd
yep....and underskinning.......
Posted: Sun Jan 10, 2021 6:55 am
by steve1313
How much fuel can you hold? I'd calculate my fuel distance range and make sure I have plenty of reserve to get to each fuel stop.
Posted: Sun Jan 10, 2021 4:55 pm
by jlh3rd
25 gallon tank. I've installed a " smart tach" ( mercury) about 3 years ago and is very accurate with fuel burn. I've calculated,roughly, around a 100 mile range at cruise of around 10 mph. That'll change if a bigger motor is used. There'll be extra fuel.....I read there can be some extended stretches.........
Posted: Tue Jan 19, 2021 4:56 pm
by bansil
Well some folks took a cat with like a 10 hp outboard clamped to angle iron to Florida.....I would do it, weather window for bay crossings, but 99% is inside
Look up 9to5less on YouTube, dude is cool...chick was cray, cray tho
Posted: Thu Jan 21, 2021 7:05 pm
by jlh3rd
interesting stuff...crazy....2 years?...
will watch more...
Posted: Fri Jan 22, 2021 6:40 am
The record holder on the Great Loop was actually a gentleman running a tritoon boat with a big motor. And he just stayed on the move all the time--stopping only to sleep a little. Don't you know his body was about beat after 5000 miles of running the boat.
But there's no way I'd want to make such a run in a 2 toon, 60 hp boat that's not capable of handling big waves and/or outrunning storms. And I wouldn't want to make the trip with a slow moving sailboat.
Trailer the boat to Florida and start the trip north from there as the ICW is better down there. Any problems and you would have the trailer behind you to transport the boat.
Posted: Mon Jan 25, 2021 4:24 pm
by jlh3rd
yep, read some of his story......5,000 miles would never work....I'm not even sure about a thousand.....
good points.
Posted: Tue Jan 26, 2021 4:57 pm
by bansil
Alot depends on two factors
1) age
2) cash flow
Iam old and broke so I will have to wait
Posted: Fri Jan 29, 2021 5:25 am
by jlh3rd
well, age doesn't stop me (67.5). ..in the gym m-f....do all my home and auto repairs....no couch potato......stuff like that....
yep, read about the costs......I'm not rich either, retired.......
