Mooring cover install
bamaegghead
#1 Post by bamaegghead » Wed Aug 24, 2016 9:42 am
Ordered a cover from pontoon since it did not have one. Has anyone ever installed one that did not already have snaps in place? Tips?
Thanks for the help!
Gonefishing
Re: Mooring cover install
#2 Post by Gonefishing » Thu Sep 15, 2016 9:52 am
Not hard to do. You can purchase a snap tool with snaps they are not expensive at all. Then just mark where you need the snaps male and female. When installing the male which will have a small screw on the back drill a pilot hole first. Also if you have a way to reinforce the fabric for the female snap I would do that also.
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
#3 Post by curtiscapk » Thu Sep 15, 2016 11:10 am
bamaegghead wrote:Ordered a cover from pontoon since it did not have one. Has anyone ever installed one that did not already have snaps in place? Tips?
generic cover from pontoonstuff? or a custom cover?
guy48065
guy48065
#4 Post by guy48065 » Mon Sep 19, 2016 10:58 am
Unless ive missed something, Pontoonstuff doesn't sell custom OR mooring covers. Only generic storage covers.
Mark
Rush Lake, Atlanta, MI
#5 Post by curtiscapk » Tue Sep 20, 2016 6:51 am
yes your right, but wasn't sure exactly what this meant...
#6 Post by Bamaman » Tue Sep 20, 2016 8:19 am
Yes, you'll have to install new snaps to correspond with the other half of the snaps on the anodized square tubing.
Installation will work better if you leave the cover out in the sun prior to starting adding the snaps--warm it up.
Then install the snaps one by one .
guy48065
#7 Post by guy48065 » Tue Sep 20, 2016 8:58 am
If it IS a generic storage cover don't bother adding the snaps because they'll just tear out. Those covers don't fit tight like a mooring cover and flapping in the wind will tatter the material at the snap locations. Just use the rope or elastic in the hem & the tie-down loops to secure it.
That's what I'm dealing with on the pontoon I just bought. PO added snaps around the beltline and most of them have torn the cover. I don't have $800+ for a custom mooring cover so I'm looking at my options for next season because I'm not going to deal with this floppy torn cover next year.
I wish someone made generic MOORING covers that would come in several sizes for a "close enough" fit once I add the snaps in the correct locations. Realistically most pontoon playpens are so similar in size & shape that this could work but canvas shops are raking in the $$ making custom covers one-at-a-time and not making patterns to save the next customer money.
Mark
#8 Post by curtiscapk » Tue Sep 20, 2016 11:00 am
I love my PS cover! I used doubled up snap straps to make my peak higher water flows right off.
Rick McC.
#9 Post by Rick McC. » Sat Apr 01, 2017 8:56 pm
[IMG]http://i294.photobucket.com/albums/mm11 ... G_1128.jpg[/IMG]
Had to put the snaps on myself; no big deal at all.
guy48065
#10 Post by guy48065 » Mon Apr 03, 2017 9:37 am
Here it is a new season & I'm still no closer to finding a mooring cover that will fit my short 15' playpen.
There are several "good enough if you don't really care" covers on eBay but all have large-radius corners, while my 'toon is typical of older models that have the small-radius bends. I think the "pointy-er" small radius will eventually rip through the wider sweep of the newer pattern.
Mark
