#46
Post
by bansil » Tue Jun 05, 2018 3:14 pm
So i rereaded
So after that , ignore most of what i said, pull off starter and test it for function, there could just be corrosion holding it back ie the spring or grooves rusty that the little gear rides in on armature
Sorry for bad info
TWB
#47
Post
by TWB » Wed Jun 06, 2018 11:51 am
bansil wrote: ↑Tue Jun 05, 2018 3:14 pm
So i rereaded
Sorry for bad info
Sometimes when I rereaded things, it makes better sense. Most of the time......not. Usually it just means no more beer for me.
Gonna be pulling the starter this afternoon. Gonna try shooting the Bendix and the armature shaft with Dry Lube first to see if some minor gunk will pop loose. Then on to the next part.
#48
Post
by bansil » Wed Jun 06, 2018 3:09 pm
It was actually wine, my good mate [snob]
[/snob]
Of course.............. it was
BOX wine
TWB
#49
Post
by TWB » Wed Jun 06, 2018 5:53 pm
bansil wrote: ↑Wed Jun 06, 2018 3:09 pm
[/snob]
BOX wine
HAHAHAHAHA!
TWB
#50
Post
by TWB » Fri Jun 08, 2018 5:04 am
- Mike-Me-boat.gif (81.74 KiB) Viewed 17907 times
#51
Post
by bansil » Fri Jun 08, 2018 5:15 am
TWB
#52
Post
by TWB » Fri Jun 08, 2018 5:25 am
bansil wrote: ↑Fri Jun 08, 2018 5:15 am
sweet.................
Gonna owe you a box o' Franzia. Lots of great advice about where to look and how to approach. Thanks, man.
#53
Post
by bansil » Fri Jun 08, 2018 9:25 am
No problem, just glad you are back on water....you got that pretty water where you toon, or just deep ocean?
TWB
#54
Post
by TWB » Fri Jun 08, 2018 6:36 pm
We live on the Santa Rosa Sound - the intercostal waterway. That beautiful emerald green water of the Gulf is 1.2 miles "across the street" from us. The Sound is not the most perfect water, but is enjoyable for boating. More chop and tide concerns than a lake. The large plus is (usually) the weather stays nice a good long time. One of the downsides is the depth. Especially at low tide, you can wade into the Sound a couple hundred yards at no more than chest deep. LOTS of 2' - 3' shallows.
#55
Post
by bansil » Sat Jun 09, 2018 4:24 am
wow, cool...heading to the lake today after making a run to the dump
Gotta plot a course from the slip to where the fire works will be on the 4th (about an hour ride), so we can make it home at midnight
TWB
#56
Post
by TWB » Wed Jun 20, 2018 5:36 am
Please allow me this moment........
TRILOBE PINS SUCK!!!! And maybe even the guy who invented them.
Trying to replace the trim motor and the ram trilobe pin won't budge. Ended up breaking the head off. Dammit! Reading a thousand forums, etc. some recommend pound the main pin through and shear the trilobe pin off. Um.... no. Not happening.
Gonna get that bitch off if I have to take a flamethrower and a couple of artillery rounds to it.
Anybody else ever had to come up with a solution?
#57
Post
by bansil » Wed Jun 20, 2018 10:06 am
all I found was make sure motor is all the way up, ensure strong support/safety bars in place (takes the load off the main pin so trilobe pin has no force on it) and either vice grip and turn out OR beat the shit out of it until you have clearance under the mushroom head for a clawed pry bar...but since you dont have the head on it any more
good luck with it,
steve1313
#58
Post
by steve1313 » Tue Jun 26, 2018 2:07 am
TWB wrote: ↑Fri Jun 08, 2018 5:25 am
Glad you solved the problem, but you need to up your wine game!! Franzia???? If you're going to limit yourself to box wine at least go for Black Box!
TWB
#59
Post
by TWB » Tue Jun 26, 2018 9:02 am
steve1313 wrote: ↑Tue Jun 26, 2018 2:07 am
HAHAHA! Franzia is a choice
bansil enjoys. I usually only have wine when I want to REALLY mellow out. Beer and Bourbon are my choices.
#60
Post
by bansil » Wed Jun 27, 2018 4:06 am
I like my Bourbon at the fire pit
weekends are bottle wine days
