two questions, I'm sure the answers are here
WayneElkGrove
#1 Post by WayneElkGrove » Wed Jun 24, 2020 7:44 am
Hello,
Im rebuilding the floor and putting new carpet on my 90 Lowe 20'.
There are three 4 x 8', but the board in the front is a 5 x 8. This presents a problem as that isn't available. I don't have a ton of mechanical ability to move the frame or weld or anything of that nature. So what's the solution?
Also, has anyone seen a wiring diagram for these boats for ease of disassembly?
Thanks for any help!
Steiner
Re: two questions, I'm sure the answers are here
#2 Post by Steiner » Wed Jun 24, 2020 10:29 am
Maybe two 4x8's cut off to 5' and turned longways?
I don't know if manufacturers even have wiring diagrams to tell you the truth.
One thing is to sketch everything, label, and number it on your sketch and then get you some wire number tape to label the wires with. Also mark stuff with a sharpie as a fall back.
#3 Post by bansil » Thu Jun 25, 2020 4:03 pm
What Steiner said would be my guess, is there support done center of boat to hold toe 2 sheets cut to 48 x 60?
mgarvie
#4 Post by mgarvie » Fri Jun 26, 2020 6:52 am
This link should help identify which wires are which.
https://www.mtboats.com/wirecolors.html
sunedog
#5 Post by sunedog » Fri Jun 26, 2020 1:28 pm
And this is the best generic wiring diagram I have seen. Don't remember where I found it. It's kind of intimidating lying on your back inside the console and looking up. This clearly explains the wiring to the helm switches.
gerard143
#6 Post by gerard143 » Sat Jun 27, 2020 7:58 am
go to newwiremarine.com and download their wiring guide!
#7 Post by curtiscapk » Mon Jun 29, 2020 6:24 am
or buy a new harness has almost all you need..
https://www.pontoonstuff.com/collection ... ng-harness
TWB
#8 Post by TWB » Thu Jul 02, 2020 7:30 am
During my rebuild I was going to fight all the old wiring and try to make it neat and workable. Finally said to Hell with it and ordered the wiring harness from PS. Best decision I made.
Paul & Michele
2003 Mercury 75hp
TheWhisker
#9 Post by TheWhisker » Thu Jul 02, 2020 9:29 am
I can't argue that one! I eliminated the analog gauges during my rebuild and saved a ton of time not having to work with the old wiring. Had I used analog, I would definitely have gotten a new harness. If you factor your labor into the equation (as well as potential failures of old wiring), it just makes sense.
2007 Suncatcher 208C, Yamaha F90 fully rebuilt as a fishing vessel
1996 Ford E-350 conversion van, 460 w/4.10 Dana rear (the tow vehicle)
fieldboss
#10 Post by fieldboss » Thu Jul 30, 2020 1:16 pm
july 30, 20
probably to late to help but I just re-carpeted a Fisher 20' with a composite type deck by myself.
As many pictures and video that I took of the wiring block, I knew I would have problems
putting it back together.
So I did Not take the helm off. I took the hold down Lag screws out and then did an intial
laydow of the carpet. I cut of the carpet to the metal rod was about a 18" from the fence.
The space between the fence to the helm outside wall is about 6 inches.
When I glued it down, the cut seam was almost seamless.
Doing it myself I elvated the Helm with a couple of 4 x4s.
This is something I would never do again.
