Ok time to start thinking about this, it hit 51 in Ohio today.
I need to have a fender re-welded on my trailer. Will it harm the toon if it is loaded at the time? I thought I read something about it causing pitting???
I have a bunk style and the boards have carpet, maby a small tear on one side I'm planning on fixing when the toon is off.
Welding
Re: Welding
I wouldn't take any chances with spatter hitting the logs. If you can't unload it then at least protect it with something.
- moregooder
Re: Welding
If the work is in close to something that I don't wont to get smoke, flames, and spatter on I will use a peace of tin or something nonflammable to use as a heat shield, using a better rod will help with the spatter also.
Re: Welding
if your close to the toon, then just throw something up between the 2 and you should be fine...
What kinda welder?
Best to be TIG'ed, but MIG will be fine... just make sure the guy uses gas as it will splatter less then if he uses those cheezy core wires...
What kinda welder?
Colorado Springs, CO.
Re: Welding
Thanks Guys,
I will make sure we protect the log during the weld, if I am able I may wait and drop the toon in the water with the family and then get the trailer fixed. We garage ours year round and haul back and forth so it's the only time the boats not on it.
Snider4
Misty Harbor 2080RE
Merc 50
Sprinter Select 26BH
Ohio
Misty Harbor 2080RE
Merc 50
Ohio
leon phelps
Re: Welding
I would risk the ticket for the fender being broken and launch the boat.
The risk of losing your toon is not worth the reward of the fixed fender in my opinion.
- bug73
Re: Welding
Yeah protect it for sure. Remove the boat if you can.
"The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails."
- William Arthur Ward
25 foot Catalina Sailboat
