gauges
LVjayhawk15
gauges
#1 Post by LVjayhawk15 » Sat Sep 08, 2012 4:11 pm
So on the way back to dock after her maiden voyage this morning a temp light kicked on. (other than that, it was great! lol)
Which lead me to notice there isn't a water temp or pressure gauge, obviously if I had a water pressure guage, maybe (just maybe) i would have seen something prior to leaving dock.
Did anyone install these? Would it be worth it?
Random note:
The red light came on after running WOT for maybe 1 min continuous. I assumed I had some blockage (depth was plenty) so I shut it off, dove in and felt around, looked good, no block. Fired up, was temp light was still on so we came in.
As usual, thoughts appreciated
"I bust mine so I can kick yours"
--Corrie--
Re: gauges
#2 Post by lakerunner » Sat Sep 08, 2012 7:29 pm
Sounds like a water pump going out or thermostat
GregF
Re: gauges
#3 Post by GregF » Sat Sep 08, 2012 8:54 pm
Yes I installed a water pressure gauge, for exactly the reason you are asking the question. I had an overheating problem and the gauge pointed out the problem.
1974 Harris
70 HP 4 stroke EFI Yamaha
