short shaft
short shaft
Could I use a short shaft on my 18' toon ...or does it need to be a long shaft
Re: short shaft
...leaving yourself WIDE open on this post
Michael
Rough River Lake, Kentucky
50 HP 2003 2-stroke Mercury
Re: short shaft
Most pontoons use 20" motors. Any engines that are shorter than 20" probably won't have the power to push a pontoon, even @ 18'.
I'll stop at that.
I'll stop at that.
Re: short shaft
YES, but you will get more women on it with a long shaft
Re: short shaft
As long as her legs are wide open... I'm in short or long ...lol
Re: short shaft
clownin wrote:Could I use a short shaft on my 18' toon ...or does it need to be a long shaft
It all depends on how deep you set the engine in.
See, that comment is true in several ways.
Seriously though, if you can set the engine down enough, then a short shaft lower unit might work for you. Just have to watch for cavitation.
"Nauti Weasel"
2005 Beachcomber Islander 26
buzzardbeak
Re: short shaft
With a long shaft, don't you get a better hole shot????
2008 Crestliner 2185
2009 Merc 90 4 strk
Western Washington
2009 Merc 90 4 strk
Western Washington
Re: short shaft
I'm just going to get in trouble with this...buzzardbeak wrote:With a long shaft, don't you get a better hole shot????
