Doel fin???
Themacdadt
Doel fin???
#1 Post by Themacdadt » Sun Apr 05, 2015 10:35 am
I see there's a lot of mixed feelings on this subject so.....
1. Pro's with them
2. Cons with them
I have a 21 foot pontoon withe a 75hp Mercury and was wondering if I Would benifit with one.
Todd
2008 Beachcomber 20 ft.
2006 Mercury optimax 75
East coast central fl. Cocoa beach.
Re: Doel fin???
#2 Post by lakerunner » Sun Apr 05, 2015 11:20 am
Do you have a ventilation problem? Thats the only thing I know on a pontoon one will help.
Themacdadt
Re: Doel fin???
#3 Post by Themacdadt » Sun Apr 05, 2015 12:46 pm
lakerunner wrote:Do you have a ventilation problem? Thats the only thing I know on a pontoon one will help.
What I got going on is.... My motor is mounted as low as it will go, while cruising down the river the water line is about 1-2 inches above the cavitation plate. So in theory my moter should be raised a bit correct?.. Now while also underway I will try to trim up to see if I can get the cavitation plate closer to the waterline but then I loose speed and maybe grabbing some air as well from what I can hear and feel. This is my first no planing hull and I don't expect to but I do feel and see a litte differance when I trim up with speed and bow rise. My prop is a 14 x 11 pitch.
So in theory if I raise the motor and keep in trimmed down i May still have the same effect as if I was trimming up how it is mounted now correct?
Todd
Re: Doel fin???
#4 Post by Bryden24shp » Sun Apr 05, 2015 8:29 pm
Raise it up 2 holes and try it. Will only take a few minutes. If it doesn't work, drop 1 hole and run it again. I wouldn't spend any money on anything, before I tried the free stuff, first.
BoatCop
Re: Doel fin???
#5 Post by BoatCop » Sun Apr 05, 2015 8:48 pm
The only thing a Doel-Fin will really help is in planing out quicker. Not really an issue with pontoons, which are essentially displacement hulls.
Alan
2016 Chevy Tahoe
2009 GMC Sierra
2001 Jeep TJ Wrangler
1999 Southwind 34L MH
2 little Basset Hounds
Themacdadt
Re: Doel fin???
#6 Post by Themacdadt » Mon Apr 06, 2015 3:52 pm
[quote="Bryden24shp"]Raise it up 2 holes and try it. Will only take a few minutes. If it doesn't work, drop 1 hole and run it again. I wouldn't spend any money on anything, before I tried the free stuff, first
I know the cavitation plate needs to be at surface level, so should I raise the motor to where it's at that level with the trim all the down or raise it to that level to where the motor is level ( by level I mean straight up and down) seems like when it's trimmed all the way down its past being level.
Todd
BobG
Re: Doel fin???
#7 Post by BobG » Tue Apr 07, 2015 7:57 am
What you really need is 150-200 HP and lifting strakes.
That's my $0.000002 worth.
