Where can I find the wrench used to remove the spark plugs from an
outboard motor? Especially no 4 that is below the cowling. thanks old jim
spark plug erench
Re: spark plug erench
I use a socket that has a hex on the back and a box end wrench on the hex
this may help Jim
this sort of spark plug socket has a hex end and you can fit a standard box end wrench on it, it works very well in a close space, how ever it will take a bit of time to work out a plug, but it works
- box end.JPG (83.05 KiB) Viewed 1420 times
- plug socket.jpg (73.92 KiB) Viewed 1420 times
Thanks, I did find some pictures on Amazon.
