brake horsepower rpms vs max rpms - propping
Joseph Elliott
#1 Post by Joseph Elliott » Tue Jun 07, 2016 6:41 am
When you are propping are you looking to use the max rpms possible for the motor or the manufacture's certified brake horsepower rpms? for example my motor has a max rpm of 6000 but the horsepower(60) is certified brake at 5500 rpms.
Alberta, Canada
Home made 16' pontoon, 1980 60HP Johnson- work in progress
teecro
Re: brake horsepower rpms vs max rpms - propping
#2 Post by teecro » Tue Jun 07, 2016 7:29 am
You are looking to avoid going over the Owner's Manual recommended Wide Open Throttle setting...
Joseph Elliott
#3 Post by Joseph Elliott » Tue Jun 07, 2016 8:56 am
Ok, Thank you. Also my owners manual has a list of approved props to use with this engine, are there any risks to deviating from the sizes listed? No worries about warranty, its a motor from 1980.
Alberta, Canada
