LOL. My bad, just looked it up on the web. You may still want to look into cupping your prop. It'll drop your rpms by 200 and you'll get ride of that slip your getting. I did it to my prop and is solved all my issues, both prop slip and blowout during cornering.BoatCop wrote:Simonizing is a slang term for having the engine ECU flashed to obtain maximum horsepower. To save production costs, many engine manufacturers offer a variety of HP working off the same engine platform. eg bore, stroke, displacement, etc. For example, the Mercury 4 stroke 75, 90, and 115 and identical engines, except for the ECU. By changing timing, fuel injection and, in the larger supercharged engines like the Mercury Verado, boost pressure, they can regulate HP, without changing mechanical features.slingshot wrote:Like someone said, that 4 blade is a cleaver or surface prop. I too doubt you'll get good results. Simonizing pontoon props is a bad idea. You'll just get a bunch of prop slip which I think you're experiencing. "Cup" the Black Max and you should get better results. Good luck.
It has nothing to do with the prop, except that a different prop may be required to take maximum advantage of the increased HP. Simon Motorsports in San Diego is one of the main companies to do this. Hence the term "Simonize".
My Simonized 90-115+ Findings
Re: My Simonized 90-115+ Findings
2007, 2570 Crest LE II
Yamaha F150
Yamaha F150
My wife calls everything I do... Bryanizing! I can see a Simon pounding on a prop!
