Beaching a Pontoon Boat
Scott1
Re: Beaching a Pontoon Boat
#16 Post by Scott1 » Mon Aug 22, 2016 6:23 pm
JerEazy wrote:
curtiscapk wrote:
JerEazy wrote:[I honestly don't see a problem with it as I also do the same thing, once the engine is off. I get everyone off the toon, walk up front and lift/pull it up as far as a can, walk around back and make sure there are no rocks, and trim the motor down with the switch on the motor. It never gets buried deep enough to get sand in the intakes. 20+ years of boating and never had an issue doing this. If the water is too deep to do this I run lines from the back off each side to shore with sand anchors
In theory it's fine - the odds of a current pushing you hard enough to bend the skeg is minimal. But what is more likely is a passing wake lifting the stern of the boat and having it crash back down into the sand/mud. And packed sand can be hard enough to bend a skeg. Or you get mud/sand into your water passages.
If you're on a tidal river or body of water the tide coming in will cause the skeg to no longer work as an anchor.
Tide going out sinks it further in than you think.
And those are just a few of the potential issues. Let alone the whole list of "What-If's" that could happen ranging from forgetting to trim it out before you back off the beach, to someone bumping your boat while they are pulling in and causing damage to now not only your boat, but your engine as well.
A $20 mushroom anchor or slip-ring danforth style and $20 worth of rode is cheap insurance compared the potential issues of using your skeg as an anchor.
wow after 8 years not one of these have happened.... I'm glad I don't boat around you....
Good for you guys!! :thumbsup
Just because they haven't happened doesn't mean they can't or wont. Let's look at some other famous boating quotes:
"I never strap down the rear of the boat to the trailer. Been doing it like this for years and never had an issue."
"I always use regular fuel with ethanol from the gas station. It's easier to get and less expensive. Been doing it for years and haven't had an issue."
"There's no need for a fuse on that wiring. I direct wired mine to the battery and haven't had an issue for years"
"It doesn't get really cold here. I didn't winterize the engine last year and it was fine."
"I never turn my blower on before I start and haven't blown up my boat yet." (For those who have I/Os)
"You wont hurt anything by running your engine out of the water. As long as it's not for too long."
Moral of the story is, don't use your skeg as an anchor. Use an anchor as an anchor.
What is wrong using fuel with ethanol? This is all you can get in many States, and newer boats are fine with it. If you look it up, the boating manufacturers will tell you it was only the old boat fuel systems that you had to worry about. I don't like ethanol and am against it in fuel, but I have been using it for 15 years, as most other people in my State.
2014 Bennington 2375 RCW with Verado 250 Pro and Simon Motorsports ECM upgrade to 325 HP
Tri Toon with ESP package
C_M_25
#17 Post by C_M_25 » Mon Aug 22, 2016 7:32 pm
I'm over here worrying about my fish finder transducer and you guys are using the motor as an anchor. :scared
I think I'm going to avoid that with a 10 ft pole. Too many things could go wrong. It puts stress on the hydraulics, transom, as well as the boat itself. I really like the anchor buddy idea and keeping the boat slightly offshore and walking in. I just don't like the back of the boat sitting on sand. Especially if nobody is around to help me push off.
2014 Sweetwater 2086SW
90 Hp Yamaha 4-stroke
JerEazy
#18 Post by JerEazy » Tue Aug 23, 2016 3:18 am
C_M_25 wrote:I'm over here worrying about my fish finder transducer and you guys are using the motor as an anchor. :scared
There yah go.
Anchoring from the stern to the shore works well holding the boat steady as well. And, is easy to adjust for tide movement.
Happy boating!
-Beaches Love Me
'03 Odyssey 21- 90hp Johnson
abypfcs
#19 Post by abypfcs » Tue Aug 23, 2016 3:57 am
I say, whatever works for you, do it. I sure don't need for my pontoon to cause any additional stress in my life.
I also will not tell anyone else what they should or shouldn't be doing. (I will leave that to my Wife) :biggrin2
[i][size=85]2014 Bennington 18SFX
Yamaha T60LB
Minn Kota I-pilot 55lb 54"
Lowrance HDS 7
Power Pole Blade
Wash Down System[/size][/i]
#20 Post by curtiscapk » Tue Aug 23, 2016 6:22 am
I also stated if its to windy I'll anchor... I guess being on a non-busy lake makes a difference :eviltaunt
All 3 of these are pegged...
