Steering setups without tube through engine
hvymtl939
#1 Post by hvymtl939 » Wed Jan 11, 2017 8:58 am
So, my motor is a 1972 Johnson 65 hp. It does not have a provision to run the steering cable through a tube on the motor mount. If any of you have a motor like this, how do you run your steering? I've attached pictures of my transom, and a couple of different mount options. I was thinking the stringer style mount would be easiest, but I'm not sure the best place to put the bracket to hold the steering tube. If that wouldn't work, I was thinking a splashwell mount, cut through the aluminum pod could. What would you guys suggest?
MH Hawker
Re: Steering setups without tube through engine
#2 Post by MH Hawker » Wed Jan 11, 2017 10:19 am
i doubt a splash well mount will work its way to low but the transom one should
hvymtl939
#3 Post by hvymtl939 » Wed Jan 11, 2017 10:31 am
[quote="MH Hawker"]i doubt a splash well mount will work its way to low but the transom one should[/quote]
Where would you recommend mounting it? I guess that it will just depend on where the motor sits once it's bolted up.
MH Hawker
#4 Post by MH Hawker » Wed Jan 11, 2017 2:58 pm
you will have to make a mounting bracket to fit on the side of the splash well
hvymtl939
#5 Post by hvymtl939 » Thu Jan 12, 2017 9:18 am
Well, potentially picking up a parts boat tomorrow with a 75 hp johnson, so this might end up being a non-issue.
