fenders
Re: fenders
My favorites are the ones that have a flat side and a notch that the trim on th deck fits in so they wont roll up and out as easy.
http://www.overtons.com/modperl/product ... &i=1053925
Re: fenders
I use the same ones.
SMLTOONER
Ted & Emily
2019 Bennington 21SL Tri-toon
2019 Yamaha 150 HP
Smith Mtn. Lake, Virginia
Ted & Emily
2019 Yamaha 150 HP
Re: fenders
Do these things have to be semi "installed" before launch ? can they be easily moved from side to side once on the water?
Re: fenders
you can install them on the water at any time. You lower them below the deck trim and then pull up to snug them on the trim piece. The EZfenders that a member makes here are probably an easy way to attach them and hold them in place. I don't have them yet but need to get some.
Re: fenders
EZ Fender's are a must!
- Loosen thumb screw adjust length, tighten.
- SAM_2767.JPG (293.28 KiB) Viewed 3512 times
