Fuel filter
msparks
Fuel filter
#1 Post by msparks » Wed May 29, 2019 5:11 pm
Is this a fuel filter? I’ve never seen one like this.
is this a fuel filter ?
Liquid Asset
Re: Fuel filter
#2 Post by Liquid Asset » Wed May 29, 2019 5:47 pm
That is the vent for your gas tank. It let's air in but keeps fumes from escaping.
Liquid Asset
Re: Fuel filter
#3 Post by Liquid Asset » Wed May 29, 2019 6:11 pm
I should also mention the it keeps pressure in the tank from backing up when the gas in the tank expands. It acts as a check valve.
boocat
Re: Fuel filter
#4 Post by boocat » Thu May 30, 2019 3:35 am
msparks
Re: Fuel filter
#5 Post by msparks » Thu May 30, 2019 7:30 am
Thanks Liquid. Apparently I don’t have a in line filter. I have a water separating one on the fuel pump. I guess I could just get one from the parts store?
2014 Sun Tracker 20'
60hp Bigfoot Mercury
msparks
Re: Fuel filter
#6 Post by msparks » Thu May 30, 2019 7:46 am
Also, does it ever need to be replaced? I was going through a no wake zone and the engine died. It started back up but it’s done it a couple times.
steve1313
Re: Fuel filter
#7 Post by steve1313 » Fri May 31, 2019 2:53 am
The fuel/water separator is a fuel filter, and you also have one on the motor. You should probably change both.
Here's a link to replacing the one on the motor.
https://www.youtube.com/watch?v=rnPejtbrCRM
msparks
Re: Fuel filter
#8 Post by msparks » Fri May 31, 2019 9:11 am
Do you think I should change the vent valve? It’s never been changed. Thanks for the advice.
Liquid Asset
Re: Fuel filter
#9 Post by Liquid Asset » Fri May 31, 2019 3:17 pm
I don't think you need to replace it. I would definitely change the fuel filters and go from there. I've always replaced my water separator/filter annually. Mine was a external spin on type.
