How do I prevent mildew on my seats and such during the wint
Re: How do I prevent mildew on my seats and such during the wint
I live at Lake of the Ozarks in central Missouri where we sometimes can't get our boat out for months at a time. I have always had good results with a bag of the cheapest charcoal. I lay the bag out flat and slice open the side facing up about 2/3rds of the way. This stops a lot of mildew from forming. Our boats are stored on lifts and so are exposed to the elements all the time. One year I forgot to put the charcoal in and we had ourselves a time getting the mildew out!
I think a box fan might work, but that could get expensive from an electricity usage standpoint. You might want to invest in some kind of timer that could control the on/off time.
We've tried HumidDry, but you'll have to check it periodically and refill as necessary. That could kind of be a pain in the butt (or knees).
Good luck!
Good luck!
F225 Yamaha
F225 Yamaha
Could be they went to bug who hasn't been around in a long time
Dam I didn't get it either and I check my filter everyday for people in trouble and hope I don't make it worse.badmoonrising wrote:I never got a message from you, otherwise I would have fixed your old account...
Yea I talk to bug more on face book now days
It's all Mike's fault
I decided to spray some lysol all over the carpet and in the compartments and wiped the seats with lysol wipes (no bleach in them) and put a couple buckets of charcoal in. I think I am going to add the humidity remover buckets too but have a feeling they will fill and get used up very quickly.
Tahoe 24 Fish n Fun
115 4 stroke Mercury
2003 Ram 3500
Harpersville, AL
2003 Ram 3500
Harpersville, AL
I have a Premiere 235 Tri Toon and it sits on a lift at my dock over the winter. I'm in western NC on a lake and get a lot of wind and driving rain across the water. My carpet is always wet, not from the rain but the moisture seeping in and high humidity condition under my sunbrella cover. When I pull off my custom cover, mildew is everywhere. I have been using the 50 50 chlorox and water number and it gets 90 percent off but now the repeated mildew stain appears permanent.
My question is, will this bucket or buckets of charcoal keep the mildew at bay or do I need to cover the seat cushions with old sheets first, after having applied UV protectant first and maybe that huge tarp tied down somehow?
My first time posting. A great site!
JohnC, aka kc4yxb
JohnC, aka kc4yxb
Wow a 6 year old thread back to life on your first post!
First off stop using Clorox on your seats it is going to ROT the stitching right out of your seats... Clean mildew with Amazing Cleaner by Bio-Clean or LA's Totally Awesome Cleaner and protect your seat with 303 Aerospace Portectant.
Sheets will do nothing to help as once they are wet they will then be wet sheets in contact with your seats...
Large Pans of charcoal will have much more surface area than buckets of charcoal and will thus better absorb moisture.
Do you have the means of keeping air flowing under your cover by way of a couple of fans? This will greatly control standing moisture.
Also keep in mind that covers must be breathable to let moisture that gets in back out so just be sure that your using breathable materials to protect your boat from the weather. Blue Poly Tarps are very bad for trapping moisture....
Thanks so much for your reply! This thread must still be useful!
I will try " Clean mildew with Amazing Cleaner by Bio-Clean or LA's Totally Awesome Cleaner and protect your seat with 303 Aerospace Portectant", and put charcoal in open pans to absorb moisture. Sounds like a good idea for best absorption.
My boat does breathe a little around the center door in front. The cover snaps but gaps exists on the floor around both sides of the door. Same with the back door. I do have some air but not positive ventilation through the open area of the boat under cover as fans will produce. You still think a winter long driven fan is cost effective?
How much do you think a running fan is going to cost? No more than a couple bucks a month at the most...kc4yxb wrote:.. You still think a winter long driven fan is cost effective?
Yah, you're probably right. I wonder what power, size, cfm fan would be best for moving air out of the cabin?
No wind storm needed, generally just a small box fan on low to keep a slow but constant flow of air...kc4yxb wrote:Yah, you're probably right. I wonder what power, size, cfm fan would be best for moving air out of the cabin?
Sounds like teecro is passing along some good info to me. Good luck.
Tahoe 24 Fish n Fun
2003 Ram 3500
Harpersville, AL
2003 Ram 3500
Harpersville, AL
- STEVEBRENDA
We installed a solar vent at the back of the boat (the best position for sun light). This seems to help. There is no electrical cost. Our boat is on a light on a Corp lake. They do not allow you to leave a fan, battery charger, etc. plugged in all of the time.
2014 Regency 254
Mercury 250L Verado
Mercury 250L Verado
Might as well get this post re-lit since many people have this problem. At least it will make it easier for someone to search for. So far, ten years, I've been using the advice I got here basically. I clean it good then wipe with lysol sheets and apply 303 protectant. I put dryer sheets and moth balls galore in all the compartments and even in some open areas and a couple of buckets of charcoal. I also spray lysol in all the compartments and on the carpet. I've got some dots/spots of mildew creeping in but you have to look for it.
Tahoe 24 Fish n Fun
2003 Ram 3500
Harpersville, AL
2003 Ram 3500
Harpersville, AL
Live in central Florida and just picked up my new Bennington. Dealer told me he uses a regular pontoon cover and has one of those carpet/floor dryers he keeps under the cover and has it on a timer for about 6 hrs a day and has never had a problem with mold or mildew.
2021 Bennington 20SSX fishing/cruising
2016 Tahoe
2016 Tahoe
