Tips for Cutting Seat Pedestal?
steve1313
#1 Post by steve1313 » Wed Sep 07, 2022 3:01 am
I've got a couple of fishing chair style seats on my back bar and I want to shorten the pedestals. I think I'm going to have to cut them while they are still mounted to the floor of the boat because I'm guessing they mount with nuts and bolts which would be inaccesible from under the deck because of the underskin. I'll remove one mounting screw/bolt and if the seat bases just happen to be screwed in without nuts, then I can remove the mount and just cut them on a chop saw.
If I have to cut them while they are still mounted on the boat, does anybody have any tips or ideas on what the best saw to use? I've got a jig saw, sawzall (reciprocating), multi-tool, angle grinder, and of course a manual hacksaw. I just want to make sure that whatever I use, that I can have good control of the saw so I can do a straight cut that is parallel to the floor, otherwise the seats won't be level or sit properly.
Marc K
Re: Tips for Cutting Seat Pedestal?
#2 Post by Marc K » Wed Sep 07, 2022 5:59 am
My first reaction would be a wheel type pipe cutter? I would see if you can borrow/rent one made for thin wall steel, for a nice straight and clean cut.
Marc K
#3 Post by Marc K » Wed Sep 07, 2022 2:44 pm
Wrap a piece of heavy tape around the post as a guide and go to town with your Sawzall using a fine toothed blade. Clean up the edges with an angle grinder or rat tail file. This will make a mess compared to a pipe cutter.
steve1313
#4 Post by steve1313 » Thu Sep 08, 2022 3:17 am
Marc K-
Thanks for your suggestions. I never even thought of a pipe cutter. That certainly would be a cleaner solution than using a sawzall, etc. I need to measure the diameter of the pedestal pipe because most of the less expensive pipe cutters I see handle up to 2" pipes. I'm pretty sure the pedestal is 2" so I'd be fine.
Rick McC.
#5 Post by Rick McC. » Mon Nov 07, 2022 7:55 pm
Marc K-
So how did it work out?
steve1313
#6 Post by steve1313 » Wed Nov 09, 2022 3:53 am
Life got busy so I never got around to doing it! But I certainly will let you know how it goes when I finally get it done. But despite being busy, I did take some time to order a new toy for next season!!
Steiner
#7 Post by Steiner » Wed Nov 09, 2022 6:25 am
Joining the ranks of the lake lice?
Marc K
#8 Post by Marc K » Wed Nov 09, 2022 11:42 am
:lol3 :biggrin2
Rick McC.
#9 Post by Rick McC. » Thu Nov 10, 2022 6:43 pm
Well congrats on that! 👍
steve1313
#10 Post by steve1313 » Fri Nov 11, 2022 12:23 pm
If ya can't beat 'em, join 'em! :biggrin2 And I think if you have a boat and a PWC, you aren't considered lake lice. LOL
We'll use it mostly on weekday evenings or early mornings for a cruise on the calm lake.
