Which ss prop should I try
schmir
Re: Which ss prop should I try
#16 Post by schmir » Thu Jan 17, 2013 9:41 am
I did go to the Yamaha site. That's where I got the idea that I should try a 14x13 ss prop.
sunnyside
#17 Post by sunnyside » Thu Jan 17, 2013 5:14 pm
Bamaman wrote: You've got me stumped a little, as I would think your engine couldn't push a 17 pitch prop close to 6000 rpm's. ......... are there any prop shops or marine dealerships that are exceptional at setting up pontoon/tritoon boats in your area? You might normally use a 14 pitch prop with your engine/boat combination.
I would be looking for a propeller seller that'd let you take 3 propellers of different pitchs to the lake--and return the ones that are unsuitable.
Ditto -- agree with Bamaman. I'm not an expert but have been boating 35 years and was thinking the same way to get the optimum prop.
JohnO
#18 Post by JohnO » Thu Jan 17, 2013 7:28 pm
rbiederwolf wrote:
JohnO wrote:I am not an expert, In fact I'm still looking for a ss of my own. But I started with a 15 1/2 x 15 aluminum and tried out a 14 1/2 x 15 SS (Yamaha Reliance --- Oh baby!!!). Had all around better performance.
So I'd guess that your diameter will change at least.
John O specifically what was the differences> I have the yamaha 15.25x15p aluminum on a 150 yamaha 4stroke. I am wondering what difference a SS prop would make. Right now at 5700 rpm (WOT) I am getting 37.5 mph. Would like to spin 6000 to see if I could hit 40
What do you think???
Schmir, from what I understand the same prop in SS will spin a little less rpm's, thus you would need to go smaller, but keep the same pitch - I think???
Top speed increased by 1.7 MPH. Better hole shot, way better grip in the turns. I had almost no slip turning to port and just a little turning to stbd. I used to have lots.
175 Yamaha VMax
2016 Ford F150
