Winter Project
Re: Winter Project
Of course, my results are only appropriate for 40 +/- 2 degrees north latitude, after the vernal equinox, and before the autumnal equinox, normalized for optimal performance within -2/+3 months of the summer solstice. Your results may vary.
Re: Winter Project
Ever used an Arduino board?
I am an EE as well and am going to do a few boat related projects with it.
Mercury 90 4 stroke
Mercury 90 4 stroke
Re: Winter Project
BobG wrote:Of course, my results are only appropriate for 40 +/- 2 degrees north latitude, after the vernal equinox, and before the autumnal equinox, normalized for optimal performance within -2/+3 months of the summer solstice. Your results may vary.
Sure, now you tell me. That information would have helped with some of my rounding errors.
2007 South Bay 925 Tri-toon
5.7 Volvo I/O
5.7 Volvo I/O
Re: Winter Project
No, but I have looked into it. One of my son's ex gf's was enrolled in ITT tech or something, and needed some coaching with her semester project, and using a PicAxe, so I tutored her, and realized this was a VERY attractive device, and VERY easy to interface with almost anything.babock wrote:Ever used an Arduino board?
If I was building an autonomous flight controller for a hexacopter, I'd definitely go with the arduino solutions, but for basic electromechanical device control, this is perfect.
Re: Winter Project
BobG wrote:No, but I have looked into it. One of my son's ex gf's was enrolled in ITT tech or something, and needed some coaching with her semester project, and using a PicAxe, so I tutored her, and realized this was a VERY attractive device, and VERY easy to interface with almost anything.babock wrote:Ever used an Arduino board?
Bob I almost got hard reading that
Re: Winter Project
I'd love to tap into some of your grey matter on this subject. Do you have any links to light reading on actuators (water proof) and how to interface with them from the control board outputs?BobG wrote:for basic electromechanical device control, this is perfect.
Due to age, my cheese is slowly starting to slip off the cracker so little words are best
Re: Winter Project
OK, so actuators are the big deal here.tuned wrote:I'd love to tap into some of your grey matter on this subject. Do you have any links to light reading on actuators (water proof) and how to interface with them from the control board outputs?
Basically, I said I need a 12 volt actuator:
http://www.dcactuators.com/Detail.asp?P ... .160_6112C
My mechanical design showed that I needed 12 inches of travel.
And, they have to be water resistant, or water proof. Here's where you learn about "IP" ratings. The IP rating of the actuator I chose is IP67. You can google IP ratings to see what that means, but it's pretty good, and actually, not real common.
You run the 12 volts through them in one direction to extend them, and you reverse it to retract them.
Most have built in limit switches, so once they get to the end, they automagically stop. The actuators I chose also have reed switches, so you can count the pulses as it moves (or just verify whether or not it IS still moving).
In addition, I run the motor through a 0.1 ohm resistor, and measure the voltage across it (with the analog to digital converter built into the PicAxe chip. 0.5 volts = 5 amps. I want to make sure it's not drawing too much current (stalled motor).
Basically, I do all the power switching with automotive headlight relays - they can handle the current.
The PicAxe 18 development board comes WITH the drivers to handle powering the relays. Their part number for that is CHI030B - cost under $20. http://www.picaxe.com/Hardware/Project- ... ect-Board/
Re: Winter Project
Awesome simplification. Even I understood that stuff. My dog actually read it over my shoulder and had nothing snide to say. Research continues.
Re: Winter Project
BobG wrote: OK, so actuators are the big deal here.
I've emailed/called several companies for the past week and the problem I've encountered is that no one carries an IP67. That is, except for one who quoted $4800 for one
1989 28' Tracker Party Hut
115 hp 4 stroke Yamaha
Sacramento, Ca
Sacramento, Ca
