Ron, on my yamaha 4 stroke the hose connection is located high up on the left side of the motor ( left side if your standing at the back of the boat facing the motor )Ron Burgundy wrote:I tilt it so the water intakes are just barely above the water line.
Maybe I am just not seeing the water hose connection, but I have looked everywhere.
engine putters out while flushing
Re: engine putters out while flushing
Yep, it was still drawing in water, but not as much as it would have normally. It didn't run long enough to over heat, it was for maybe 5-10 seconds, as I was holding the trim button in the up position, from completely down, constantly, and it takes approx. 5-10 seconds for the motor to get high enough for the prop to be partly out of the water. This is when she just shut off like I turned the key off. No sputtering, just quit. Lowered her down, and she started with the first crank. Didn't act like it was starved for fuel, as I didn't have to crank for more than a split second.Ron Burgundy wrote:When you raised your motor was it still drawing in water? Maybe it started to overheat, and shut itself off.
The hose fitting does not readily look like a hose fitting. Look for the small black hose outside the cowling on the left side. This hose goes to the water hose adapter which is threaded onto a blind keeper. Unscrew to disconnect the adapter then attach it to your hose.ROLAND wrote:Ron, on my yamaha 4 stroke the hose connection is located high up on the left side of the motor ( left side if your standing at the back of the boat facing the motor )Ron Burgundy wrote:I tilt it so the water intakes are just barely above the water line.
RTFM - using this connection you do not need, and must not have the motor running. Also, it says for best flushing, raise the motor all the way up. I think it was designed for your situation.
2008 G3 Suncatcher 228 Fish & Cruise
Yamaha 90 hp
Dodge 2500 Diesel
Yamaha 90 hp
Dodge 2500 Diesel
- Ron Burgundy
My father in-law has a 4 stroke 250 Yamaha that has the fitting, but mine is a 2 stroke 50hp. I'll look again. Hope you are right.
