Low RPM at full throttle???
GreenGolfBall
Re: Low RPM at full throttle??? FIXED!!!!
#31 Post by GreenGolfBall » Fri May 21, 2010 7:03 am
Alright, so we took all 3 carbs off to rebuild and when we took #1 off we found one of the small gaskets (not sure what exactly it does) was torn and the jet was clogged with junk. Change the gasket, clean the jets and moved on to #2 and #3. 2 and 3 both had a little tiny piece of debris in the jets....not sure if that was affecting anything. Cleaned and reassembled everything. Pull out of the marina and give it all she's got and now she is running amazing. 5200 RPM!!! Thanks guys for all of your info and help. Now I'm ready for the season.
Parasympathetic
#32 Post by Parasympathetic » Fri May 21, 2010 7:18 am
Glad you got it figured out and are back on the lake. :nana
2015 Ranger RT175
Yamaha 70hp
Lake Wappapello, MO
#33 Post by HandymanHerb » Fri May 21, 2010 7:22 am
Good deal now you know what to tell the next guy with the problem and be a hero.
#34 Post by badmoonrising » Fri May 21, 2010 8:17 am
Probably varnish. You may want to install a water separating fuel filter if you don't already have one.
GXPWeasel
#35 Post by GXPWeasel » Fri May 21, 2010 8:23 am
Nice Job. :nana
Glad to hear you're up and running strong agin. :drink4
Woody
#36 Post by Woody » Fri May 21, 2010 8:39 am
badmoonrising wrote:Probably varnish. You may want to install a water separating fuel filter if you don't already have one.
Yes. Better safe than sorry. I bought one for mine but haven't installed it yet.
Glad to hear you have it fixed GGB. :nana :nana
2019 Veranda 22 RFL 250SHO
WaltF
#37 Post by WaltF » Fri May 21, 2010 9:44 am
Love it when a plan comes together! :rofl
Colorado Springs, CO.
GreenGolfBall
#38 Post by GreenGolfBall » Fri May 21, 2010 10:10 am
Its a good idea about the water separating filter. Yeah, the #1 carb had some blue/green crap on it. But that's the only one that had it. I've learned alot about the motor and how it works! And if it ever happens again, i'll know what to look for.
#39 Post by curtiscapk » Fri May 21, 2010 11:49 am
Great!
Mine aint as bad as yours but I know I need to clean em... Problem is I am worried about getting all four carbs synced back up.
wrenchendave
#40 Post by wrenchendave » Fri May 21, 2010 4:38 pm
Had to clean carbs on my 140 johnson, left fuel in it since october and it left the varnish in it also. Runs like a champ too. I should of put stabill in gas when i picked it up. I drained gas and it smell like the old shoe Peeww wee. Can hardly make a fire with it. had to throw fresh gas on top of old gas to get it to burn :lol3
21 ft 2009 suntracker/90optimax
LTB Racing
#41 Post by LTB Racing » Sat May 22, 2010 5:48 am
curtiscapk wrote:Great!
Synchronizing carbs on 2 strokes is not at all a complicated task....Dont let that stop ya. 8) All you are doing is loosening a couple of screws and making sure the throttle butterflies are all closed and double cking all linkage adjustments(most of which wont need any adjustment but its a good time to ck).....now sync'in carbs on a 4 stroke is more tricky and requires special tools to do it...getting them right is critical for running quality on both but neither are hard to do.
GGB- Glad you got it fixed. I highly recommend a water separating filter as well..especially with the quality of todays fuel... The best way to prevent this from happening is using the boat regularly.
LTB Racing
Quartershot T3-R Merc 2.5 260
Fiesta 18 Party Barge w/ Twin Evinrude 50's
http://WWW.LTBracing.com
"The great ones practice the basics"
