I dont think Ill be using a steel prop again.
spurhunter
#1 Post by spurhunter » Thu Jun 21, 2012 6:30 am
DAYEM....running along last Saturday and KABLAM! Assumed "shit, just blew the powerhead". The racket was awful and killed the motor. Got to look at it last night and it was the lower unit, essentially blowing up on me. Apparently the seal on the drive shaft was bad and let water in, pushing oil out, that allowed it all to get hot, all it took was one more piece to the puzzle to twist the drive shaft in two and eat every gear in there. The lower unit guy said its clear I hit something with a fresh chip out of the steel prop and this is what you get.
1985 Johnson 175 gas guzzler
2007 2500HD Duramax Z71
fredeboy
Re: I dont think Ill be using a steel prop again.
#2 Post by fredeboy » Thu Jun 21, 2012 6:52 am
:scared That looks expensive!!
spurhunter
#3 Post by spurhunter » Thu Jun 21, 2012 7:06 am
Yup. :(
#4 Post by Bamaman » Thu Jun 21, 2012 7:13 am
What a bummer.
I used to eat a aluminum prop every year, even though our lake is very deep. When I switched to stainless, I never bought another prop for my I/O.
I guess they're plus' and minus' either way to aluminum and stainless props. This could happen to anyone.
Your damage was done to very expensive parts components. Finding a whole used lower unit is the only reasonable way to make the repair. EBayMotors.com might have used lower units for your engine.
#5 Post by curtiscapk » Thu Jun 21, 2012 7:36 am
Damn!
Spur,
I found my lower for the merc 115 for $675 last spring, on ebay. Then the #1 cylinder went out on Memorial day last year. Now we are running with damn near new motor!!!
gramps
#6 Post by gramps » Thu Jun 21, 2012 8:11 am
If the motor is 28 years old I think I would buy a new one, probably not what you wanted to hear but who know what else could go wrong. There are probably some good buys on used motors out there.
2012 Berkshire, 230cl Tritoon
150hp Mercury 4stroke
Road King Trailer
Towed with a Buick Enclave
GregF
#7 Post by GregF » Thu Jun 21, 2012 8:38 am
SEI will sell you a lower unit for $700 or so. I would really worry about the power head tho., You could have wounded a rod, a bearing or more with that bad a lock up.
I doubt a hit that just caused a little ding in your prop caused all that damage. Running without any oil might tho. All it really takes is a little chip of metal, jamming a gear to do all of that. My bet is you had a bearing in the lower fail first. I little piece of the bearing started the chain reaction.
spurhunter
#8 Post by spurhunter » Thu Jun 21, 2012 9:00 am
Actually the bearings are all good, that was a total shock. The motor is fine right now, I even started it up for a second last night after pulling lower. I thought about going with a used one, but for the same money im gonna get one rebuilt with one year warranty. No brainer for me.
playcat
#9 Post by playcat » Thu Jun 21, 2012 9:03 am
I thought I was having a crappy boating season, until now! Sorry to hear about that!
playcat
JC 266 TriToon
Kerr Reservoir, VA
wrd1972
#10 Post by wrd1972 » Thu Jun 21, 2012 9:20 am
Wow nice carnage.
spurhunter
#11 Post by spurhunter » Thu Jun 21, 2012 11:35 am
If you boat a lot, and I do, this stuff happens. Good thing is he will have it ready tomorrow. Hows that for service?
bassn386
#12 Post by bassn386 » Thu Jun 21, 2012 12:29 pm
Ouch, ouch, ouch!! Both for the part and the bucks to get it fixed.
Sorry to read about your misfortune, hope the rest of the season is uneventful.
F225 Yamaha
#13 Post by Bamaman » Thu Jun 21, 2012 6:01 pm
At least you can slap a rebuilt lower unit on there in 1/2 hour. It's no long, drawn out repair.
brumbyvet.1044
#14 Post by brumbyvet.1044 » Sun Jun 24, 2012 2:25 pm
From what you have told us I don't believe you can put the blame on a stainless prop. With all the problems you had going on it could have happened with a tin prop.
Garmin 430S
Cherokee Lake, TN
spurhunter
#15 Post by spurhunter » Tue Jun 26, 2012 8:22 am
Sure, it probably could have, but to be safe Im going back to aluminum.
