Maiden voyage is a fail, ideas?
Posted: Mon Jun 25, 2012 7:58 am
Hello,
Took my new AP 240 SL out for the first time yesterday [150 Yamy 4 stroke]. I have a vibration with the motor at 2200 rpms and also at 3000 rpms. My experienced boater friend and I replicated the problem 6 or 7 times. He thinks it may be trim related. It manifested itself the first time when I played with the trim for the first time. RPMs were around 2500 and jumped to 3300 and the vibration started. I'm breaking the motor in [now at 2.7 hours] varying rpms now maxing at 4000 rpms for the next hour or so. This did not happen during the test run at the dealer of course!
Debris is not the issue, propeller is clear.
Obviously I'm waiting for a call back from the dealer but I wanted to run it by you good folks too. Also, the dealer is 2.5 hours away. I have a local dealer but he did not have the boat I wanted in stock. He'll take over warranty but I want to make sure this isn't an initial set up problem before I hand it off to the local guy.
Thanks,
Thanks,
