When we were packing up to leave, one of the guys came over and said he and his buddy the morning after we had left the previous week had heard a humming noise coming from our toon. They went over to investigate, boarded the toon and found out what was generating the noise. Turns out one of us had accidently nudged the rocker switch that sits on front of the consul (see pic) activating the pump for the live-well. I checked the live-well, but there wasn’t a drop of water in it as the valve was closed. They suggested I start the engine to make sure the batteries were not dead. It started up no problem.
I didn’t bother seeing if the live-well would pump water given we were about to leave. We will be heading up this week and I’ll check it out then.
I don’t know why on earth they put the switch, and the type of switch, in this location right next to the side-seat. At least they should have put a safety cover to prevent accidental activation. Even better I think putting it on the front of the consul with the other switches. So, I am either going to do one of the following: (1) put something behind the rocker switch to prevent it from pressing down (on); or, (2) simply pull the fuse for it.
I’m just grateful my neighbours took action and just didn’t shrug it off as ‘my’ problem. If they had not intervened, this pump would have been running non-stop for over a week!!!
Kudos’s to some good boating neighbours!
