ETHANOL
GrandpaGreg
ETHANOL
#1 Post by GrandpaGreg » Sun Aug 19, 2012 8:17 pm
ETHANOL?
HOW BIG A CONCERN IS IT?
IF IT IS A SERIOUS CONCERN, WHAT IS THE BEST SOLUTION OTHER THAN RUNNING EXPENSIVE PREMIUM FUEL?
Re: ETHANOL
#2 Post by Bamaman » Sun Aug 19, 2012 8:43 pm
Wouldn't want to leave much 90/10 gasoline in the tank over the winter. The stuff separates and an acid eats anything rubber. I'll be using a gasoline conditioner, probably the stuff my Yamaha dealer shoves at me, later this Fall.
It's better to find some 100% gas--something that's not too easy to find these days.
I run my boat every couple of days right now, and the 90/10 gas doesn't get very old. I'm not too concerned with it this time of the year.
Re: ETHANOL
#3 Post by ROLAND » Sun Aug 19, 2012 8:59 pm
GrandpaGreg wrote:ETHANOL?
GrandpaGreg.... it is a serious concern, but running premium grade fuel won't eliminate ethanol... if you can find ethanol free gas, that's the way to go, problem is finding it... they used to sell it at several stations here in my hometown, but over the last 6 months or so, those stations have cratered and are no longer selling ethanol free gas. You can go to www.pure-gas.org you'll find a listing of all the states and cities that will tell you where ethanol free gas is sold.... if you can't find ethanol free gas, then you need to add an ethanol treatment to your gas.. there are several good ones out there, Sta-bil Marine is the one I use.. but like I said, there are several good brands out there
GregF
Re: ETHANOL
#4 Post by GregF » Sun Aug 19, 2012 9:07 pm
Just keep the gas moving and you won't have a problem. I just would not want to store gas for more than a month or so. There are additives that help but I never use them. I just burn it.
Re: ETHANOL
#5 Post by HandymanHerb » Mon Aug 20, 2012 12:56 am
It's better in a jar than in a gas tank :drink4
SCbarber
Re: ETHANOL
#6 Post by SCbarber » Mon Aug 20, 2012 4:23 am
My dealer told me to burn regular gas, however my new yamaha has a built in "separator" so that is probably why.
2012 24' South Bay 522 FCR
115 Yamaha 4 stroke
Tow Vehicle: '14 Tundra Crew Max
rancherlee
Re: ETHANOL
#7 Post by rancherlee » Mon Aug 20, 2012 6:28 am
Run it, nothing wrong with it. Been running E10 for 25+ years (since I was 8 and got a 3 wheeler!) and I have yet to have an issue caused my E10 and NEVER had it separate sitting over winter. Personally I don't like the idea of using food as fuel, but as a fuel it works just fine.
Mosnowman
Re: ETHANOL
#8 Post by Mosnowman » Mon Aug 20, 2012 7:45 am
The " pure gas" iphone app works great in finding stations for you iphone users....
BUSY LIVING...
Columbia Mo BZLIVN
bassn386
Re: ETHANOL
#9 Post by bassn386 » Mon Aug 20, 2012 8:01 am
This won't help you, but it may help anyone who boats at Lake Of the Ozarks in Missouri. All the marina's on the lake only pump ethanol free fuel, thanks to a couple of folks in the Missouri legislature.
I use Mercury's KwikCare ethanol treatment when I buy 87 octane gas on land. The recommended dosage is 1 ounce per 10 gallons of fuel (that's US gallons).
At the end of the season I add SeaFoam at one ounce per gallon of fuel. I store my gas tanks at least 90% full and I use the same treatment for all my gas powered yard equipment and store them the same way.
I've been using SeaFoam for at least the last 5 years and the Mercury treatment for the last two.
I do not fog either boat motor, I just make sure I run the motor(s) until they are completely warmed up and the treated fuel has had a chance to get into the system.
I've never had an issue with starting any of my equipment using this regimen. You will see lots of suggestions, so use the one that works best for your situation.
F225 Yamaha
wwind3
Re: ETHANOL
#10 Post by wwind3 » Mon Aug 20, 2012 8:09 am
My 90 Merc Optimax just laid down on me for the second time. First time summer 2010-motor less than 18 mos old. Ethanol ate hose and fuel pump. 2nd time last Thursday-running it in my boat stall for 15 minutes-it just quit. Not sure it is ethanol related-boat is in the shop. I ran StarTron with every gallon of gas after the first incident.
Boat did sit for 4 mos last summer during drought when lake was low. Maybe that did it.
I am not pleased.
2009 LOWE SS204 25in logs
90 Merc Optimax
Motorguide W55 Wireless
Underskinning
28 GPS
Rhinohio
Re: ETHANOL
#11 Post by Rhinohio » Mon Aug 20, 2012 1:13 pm
I've had my share of ethanol problems but my real concern is the recent mandate from the EPA to go to E15. Mercury warns of using fuel with an ethanol content exceeding 10% and it's long term effects aren't yet known.
I read a painfully mind numbing report (though informative) regarding E15 and outboard motors and the results weren't pretty... in fact, almost pornographic. I have a copy I can post if anyone is bored to death or needs treatment for insomnia.
I like the way you think GregF but boating in Ohio in February can be rather unpleasant.
Mike
"I don't consider the pleasure of others my goal in life, nor do I consider my pleasure the goal of anyone else's life."
ronb
Re: ETHANOL
#12 Post by ronb » Mon Aug 20, 2012 1:17 pm
Rhinohio wrote:I like the way you think GregF but boating in Ohio in February can be rather unpleasant.
Mike
Two things come to mind right away..
You have open water in Ohio in Feb, you lucky SoB...
The next is a visual of the guys from "The Deadliest Catch"
Do you have to take a rubber dead blow mallet with you to keep the frost off?
:eviltaunt
-ron
Re: ETHANOL
#13 Post by badmoonrising » Mon Aug 20, 2012 3:09 pm
I've had my share of ethanol related issues. Had to replace my carb, lines and fuel pump in '07 when that crap ate through "ethanol safe" fuel line with a plastic liner. Little bits of dissolved plastic everywhere. I drain my tank in the winter after doing a run with Startron blue in the tank AND I use Startron in my tank during the entire boating season as well.
It's not a question IF you'll ever have ethanol fuel relaed problems, it's WHEN. We had almost 100 vessels the same year in our 2 marinas with the same issues that year, with fuel from many sources. I fill up with cans, the larger vessels fill up at a neighboring marina and they all got it.
Boat US pays ethanol damage claims...they did in my case, even the loss of 30 gallons of fuel. This was a week old tank of fuel. :x
GregF
Re: ETHANOL
#14 Post by GregF » Mon Aug 20, 2012 4:33 pm
Mike
I thought everyone in Ohio came to Florida in the winter ;)
Re: ETHANOL
#15 Post by HandymanHerb » Mon Aug 20, 2012 4:39 pm
Hey don't give them any ideals :nono :nono :nono
