Custom transom info?
Posted: Tue Aug 28, 2012 6:36 pm
Ok I've found a guy via a jonboat forum that lives about 30mins from me, he did an awesome job on his jonboat rebuild and did a ton of fab work to it...we have talked a bit and I think I'm going to give him a shot at the transom I'll be building on my future 3rd toon. He had a couple questions for me like what thickness plate I'll want and what size bracing I'll need.....here's how I plan on doing it unless y'all have different opinions?
I also seen this at the boat show, it's open on top and you can see the bracing
I'm going with at least a 150 but I'm considering a 225 also what is yalls opinions on this???? Im not looking to start the what is your boat rated for just looking for some ideas on the design that will be strongest. I'll also add that I'm buying a donor boat and going to use the tubes to build a custom tube for my boat. As of now this will be the cheapest route for me since there's no place to buy a single log around here and if I buy one up north for a couple grand then drive up there and use gas I'll just get a donor boat locally
