Bottom Paint
pontchartraintoon
Bottom Paint
#1 Post by pontchartraintoon » Mon Sep 10, 2012 8:17 am
Well, since the boat was out for Isaac, I'm redoing the bottom. It has a coat of epoxy, then bottom paint. What type of AF bottom paint are you salt water guys using? Any good deals?
Re: Bottom Paint
#2 Post by badmoonrising » Mon Sep 10, 2012 7:49 pm
I use Interlux Trilux 33, very good paint but it's about $250 a gallon :( You have to use an etching primer first on aluminum. Holds up well and my boat has less barnacles than most vessels in our marina this year. I touch up every season and repaint every 5.
Ron Burgundy
Re: Bottom Paint
#3 Post by Ron Burgundy » Tue Sep 11, 2012 12:00 am
badmoonrising wrote:I use Interlux Trilux 33.
X2
pontchartraintoon
Re: Bottom Paint
#4 Post by pontchartraintoon » Wed Sep 12, 2012 6:21 am
Thanks Guys. I pressure washed the bottom last night, and will do a little more scraping tonite. I also hit some very dirty sections of carpet where the mold was almost a solid sheet, and it came out perfect.
GregF
Re: Bottom Paint
#5 Post by GregF » Wed Sep 19, 2012 9:21 am
This boat has been in the water since July 28.
Ron Burgundy
Re: Bottom Paint
#6 Post by Ron Burgundy » Wed Sep 19, 2012 9:43 am
1928?
GregF
Re: Bottom Paint
#7 Post by GregF » Wed Sep 19, 2012 9:59 am
Less than 2 months ago. He knows because that is what the receipt says for the tilt trim rebuild and it is out because it broke again.
It may actually be less than that because it may not have got back in the water right away after it was fixed.
