20.5x8.0-10 what rim do I get?
Posted: Mon Sep 17, 2012 5:41 pm
by robdew
I can't find any marking on my tire rims and I need a new one.
Not sure how to decipher what I need based on the tire size. Would this be a 10" rim based on the last number? Or does that mean 10 ply?
I know the wheel is 5 lug on 4.5".
Re: 20.5x8.0-10 what rim do I get?
Posted: Mon Sep 17, 2012 8:04 pm
See if your trailer fenders have enough clearance to switch to 13" ST rated tires. Purchasing a tire/wheel combo might be a viable option, as some prefer a taller tire that's not turning so many rpm's.
Those wide/fat specialized trailer tires are sometimes needed to get into a shallow water ramp--to get the boat lower to the ground.
You can check ChampionTrailers.com to see if they carry the 10" wide rim. They have a big internet business and are a great source of trailer info.
Posted: Tue Sep 18, 2012 7:07 am
by robdew
I am actually trying to figure out which rim to buy from champion trailers. They aren't cheap so I want to make sure I get it right.
Pretty sure there's not enough clearance to use a tire 3" bigger but I will check. Not quite sure I want to buy three new rims right now though.
Posted: Tue Sep 18, 2012 7:45 am
Etrailer.com has your wheels @ $25-30 each.
http://www.etrailer.com/dept-pg-Tires_a ... _Inch.aspx
Posted: Tue Sep 18, 2012 6:03 pm
by MH Hawker
This is where i picked up one last year
http://www.easternmarine.com/8-and-10-Trailer-Tire-Rim/
Posted: Tue Sep 18, 2012 7:41 pm
by lakerunner
Be sure and get 10 ply tires for the rims.
