Under bow ladder - problems stowing
My boat has one of these under the bow:
http://www.bartswatersports.com/catalog ... p?id=95008
It's a great ladder and easy to deploy, but stowing it is a pain in the ass. You basically have to wiggle it up inch by inch shaking it up and down until it slides in.
It doesn't look bent or damaged.
Does anyone else have one these, seen the problem, and solved it? Can it be adjusted?
I am open for a different style of ladder but I would hope to fix what I have first. It's a very sturdy ladder.
Re: Under bow ladder - problems stowing
I took a wed strap and tied it to the bottom step, pull it up out of the water and slides right in. No pics I can try and get some this weekend but the boat is on the trailer or you can PM me with your phone number and I'll call you.
Never had any issues with the one I had and the one I have now
- CoveDweller
I'm on my second ladder, the first one I tore off because I forgot to put it up! However I have had no problem with stowing the ladder, I can reach down to the first rung and lift & slide it right in. I would guess something is bent on your ladder.
2001 SanPan 2500 FE
100 hp Yamaha 4 stroke
Power bimini top,
3-batteries, Misting system, Microwave, Inverter
Bazooka powered sub, polk audio mm651's
Clarion 720 amp, Clarion CMD6
Power bimini top,
- screwball
My ladder (4 step) is tubular and telescopes into itself. I also use a web strap attached to the last rung. It collapses into itself so I am only folding 1 14" section into the mounting bracket.
Good Luck.
Good Luck.
We are really Steve and Vesta Brown
2012 Sun Tracker 18' Party Barge w/ 75hp Merc.
A pair of 2011 Seadoo GTI-SE PWC's
2 Harley Davidson Tri-Glides '09 mine, '11 hers
[s]A couple of Polaris 500 Scrambler Quads[/s]
We take our recreation VERY seriously
Never a problem with mine - unless you don't slide it in straight.
The way I put is in, is to lean over the edge, grab the center of one, raise it up, slide it in. repeat as necessary...
If you don't stick it in straight, it'll go in crooked, knock too hard against the sides, and there will be resistance....
If you slide it in, a little bit at a time, when you get about halfway in... then you can ram it home....
Wait... we are talking about the ladder, right?
PlaynDoc wrote:Never a problem with mine - unless you don't slide it in straight.
I'll have to try this. Hope she (the boat) cooperates.....
2006 24' Sun Tracker w/ Full Enclosure, 75 HP Mercury OB
SoapPeddler
Check the top ends of the rails for burrs. Mine had some when I took it out of the box. They didn't cause any problems for me, but if you have them on yours they could be digging in on the inside of the brackets. The burrs are easily removed with a file.
Gi-Gi 2001 Sweetwater Challenger 18'
40 hp Merc
2005 GMC Envoy
2011 Mid States Trailer
Austin Lake in SW Michigan
40 hp Merc
2005 GMC Envoy
Me too forgot about that, we did a complete rebuild on the boat did a lot of little thinks that I forgot all about doing.SoapPeddler wrote:Check the top ends of the rails for burrs. Mine had some when I took it out of the box. They didn't cause any problems for me, but if you have them on yours they could be digging in on the inside of the brackets. The burrs are easily removed with a file.
