1985 Evinrude tilt and trim question
Posted: Sun Jan 27, 2013 6:27 pm
by 1arunem
Hi guys, this one doesn't pertain to my toon, but my bass boat.
It has a 1985 Evinrude 70hp with tilt and trim. Well, I had to put the boat in the back yard for a few days and my dog decided to get up in the boat and chew on my throttle lever that has the integral tilt/trim switch. As you can imagine, it is no longer functional (the tilt trim switch).
Best I can tell, it is a three wire system that of course used a momentary switch. Can I just get another typical momentary switch, wire it up similarly and remote mount it?
It was thumb operated on the throttle handle with up/down movement. It has was appears to be three contacts, the center (ground?), up and down..
Thanks..
Warren..
Re: 1985 Evinrude tilt and trim question
Posted: Sun Jan 27, 2013 6:38 pm
by cwag911
That should work, but that switch shouldn't be that much money.
Posted: Sun Jan 27, 2013 6:47 pm
by 1arunem
Problem is the handle that the switch fits in is mangled. I would have to replace the whole assembly.
Posted: Sun Jan 27, 2013 7:10 pm
by tuned
Any SPDT switch should do. Make sure it isn't too little. It doesn't carry much current tho, as it is talking to relays at the motor.
Posted: Tue Feb 19, 2013 2:58 pm
by 1arunem
FYI, I finally got around to fooling with the tilt/trim issue. I installed a SPDT switch and it seems to be working well. Hope to get on the water soon!
