Prop Spun
Polarlit
Prop Spun
#1 Post by Polarlit » Thu Jan 29, 2009 3:41 pm
What is a spun prop and does it happen often.What do you do if you are in the middle of the lake and this happens.
Thank You
Re: Prop Spun
#2 Post by HandymanHerb » Thu Jan 29, 2009 5:26 pm
Put your spare on, the props have rubber inside them to keep shock from transferring to the engine, when it goes the prop will slip but I would think you would still have slow speed.
wish2fish
Re: Prop Spun
#3 Post by wish2fish » Thu Jan 29, 2009 5:28 pm
yes it does happen. Like Herb said you should be able to limp home at lower speeds.
Re: Prop Spun
#4 Post by curtiscapk » Thu Jan 29, 2009 5:49 pm
mine went first time out last year in "new" toon. We had a little better than Idle speed after luckily it was just outside of no wake zone we hit it and spun it. :x I replaced with one of thesehttp://boatpropellers.iboats.com/Evinru ... =162016911 its a two piece buy another and you can replace just the hub on next spin or just the prop if you ding a blade real bad. I haven't got my second one yet but will before summer.
