Installing a 3 bank charger...looking for suggestions
Posted: Thu Feb 28, 2013 10:49 pm
Well....I recently purchased a Minn-Kota M 315D 3 bank charger. Looking for some ideas on install....
Location: I need to figure out a place to mount that is out of the way. Was thinking under the porta-potty holder/step (back of changing room), in one of my battery storage compartments at bow, or ????
Wire type and size. I am going to have to add lengths to the charger cable that lead to batts, as the charger may ne be close the batts, especially since two are for trolling motor and one is starting batt and they are located on opposite sides of boat. I believe 10ga should do the trick considering the longest potential distance would be around 20 feet from charger to batts.
Should wire be marine tinned wire or is good 'ol copper home wire good enough? Obviously I would use sheathed wire in either case.
Other charger install ideas/suggestions?
