Two 12V batts....what gauge wire to connect?
SoCalAngler
#1 Post by SoCalAngler » Wed Apr 24, 2013 6:07 am
I have two 12V batts connected in series for use with a 24V trolling motor.
Question.....What gauge wire should be used to connect the positive of battery #1 to the negative of battery #2? Batts are about 3-4 feet apart.
Currently, there is an 8/10 gauge wire connecting them. This is the set-up that came with the boat when I purchased. Seems to me that the wire it is not heavy enough, but I am not sure.
Thanks
2011 Keystone Outback 250RS
The_Hellbilly
Re: Two 12V batts....what gauge wire to connect?
#2 Post by The_Hellbilly » Wed Apr 24, 2013 6:53 am
I'm not an electrician, but that doesn't seem big enough. One way to tell is if they are getting hot during usage. I recommend going to your local auto parts store and getting some standard battery cables to replace them. You can also use welding leads
2005 Voyager 22ft Tritoon
2004 Honda 135hp
cwag911
#3 Post by cwag911 » Wed Apr 24, 2013 7:11 am
+1 on the auto battery cables.
Carl & Suzi
150 Honda 15x15p Enertia prop
Power assisted steering
Denver, NC Lake Norman
Pleiku, Vietnam 1971
Cycleman07
#4 Post by Cycleman07 » Wed Apr 24, 2013 8:17 am
I ran mine on my previous boat with 8 gauge and had no issue.
BobG
#5 Post by BobG » Wed Apr 24, 2013 12:52 pm
If you search the Internet, you will find tables showing you for any given length and current (that's the number of amps you're pushing), what gauge of wire you should use.
VaGent
#6 Post by VaGent » Wed Apr 24, 2013 2:21 pm
SoCalAngler wrote:I have two 12V batts connected in series for use with a 24V trolling motor.
Thanks
I would use nothing less then #4 between the batteries. it all depends on the amp draw being applied to the batteries but #4 is more then sufficient in most cases.
1993 24' Voyager 2006 E-TECH 90-Fishing Barge
1984 24' JC 2011 E-TECH 90-Family Cruiser
2010 Silverado LT Quad Cab 5.3 Vortex
MH Hawker
#7 Post by MH Hawker » Thu Apr 25, 2013 3:00 am
Its all about the amp draw, the older 12 v 55 lb thrust motors draw around 50 amps, 8 gage is just fine for short runs and connecting them up, the newer 12/24 will still have a max draw of 50 amps on 12 v and 25 amps on 24 v so its fine, but on a longer wire run from the back to up front I would go with a 6 gage due to voltage drop.
