How about black toons? Metallurgist please speak up
Posted: Thu May 16, 2013 10:59 pm
I've been cleaning my toons every year with an acid bath. Leaves them pure white. Looks good & I seal them with Sharkhide. Doesn't last, but the Sharkhide helps to slow the algae growth, a tad bit. Every time an acid bath is used it takes off a bit of metal. This can't go on forever.
I cruise the Mississippi & keep it docked there too. The underskining I put on it last year has started turning dark so the water must be acidic. (.032 2024 T3 alclad. The outer layers of 2024 are 1100 aluminum which is close to pure, yet it still turns dark.) Aluminum turning black is a layer of oxidation, same as gun bluing or the dark "scale" (a technical metallurical term) that forms on steel. This is a form of oxidation which prevents further oxidation. Looking to do something similar to my logs so that I don't have to worry about keeping them shiny every year. I'd just like them to be the same color.
A light layer of oxidation will turn my logs black (or very dark), and I'm good with that IF IT WILL NOT OXIDE FURTHER. I will seal the logs after using a treatment (bluing), so that algae doesn't get a foothold so quick. Muriatic acid will turn the toons black real quick, but I'm not sure that it won't weaken the toons by eating away too much metal. After the toons get a "scale" or "bluing" I will seal them with Sharkhide.
I've given up on keeping my toons bright & shiny when it gonna last. Why fight it? I want to go with a protective layer of oxidation & don't mind having everything below the deck dark. I'd just like to keep everything the same color throughout the year. The toons want to turn dark & I'm tired of fighting them.
My questions are: Has this been done before? If so, what is the best method of putting a layer of protective oxidation on my toons? (I don't want something that'll keep eating them, which I fear muriatic acid might do. After I get the logs a uniform color I will seal them.) I can't be the first person this has happened to, nor the first to have raised this question.
Any advice will be most appreciated.
