First time out and motor not working right
peedee
#1 Post by peedee » Thu May 30, 2013 3:14 pm
It is a Yamaha 50hp 2 stroke. In neutral it revs fine. In forward it stops at 2000rpm's like a rev limiter is kicking in. Anyone know what I should check. Put new plugs, new fuel water separater.
2005 20' Tahoe
50 Yamaha 2 Stroke
Heatman
Re: First time out and motor not working right
#2 Post by Heatman » Thu May 30, 2013 3:42 pm
Sounds like a fuel problem to me. Is the fuel filter clean? Kink in hose? Plugged vent?
Sheridan, Indiana
MPosey519
#3 Post by MPosey519 » Thu May 30, 2013 3:44 pm
maybe carbs.....I hate those things
Michael
Rough River Lake, Kentucky
50 HP 2003 2-stroke Mercury
peedee
#4 Post by peedee » Thu May 30, 2013 4:58 pm
If the carbs are messed up, does it still work in neutral? It stays at 2000 rpm as a safety issue for the motor.
2005 20' Tahoe
50 Yamaha 2 Stroke
steveiam
#5 Post by steveiam » Thu May 30, 2013 6:40 pm
Heatman wrote:Sounds like a fuel problem to me. Is the fuel filter clean? Kink in hose? Plugged vent?
When I first bought my toon the mobile mechanic recommended I put a new fuel line on as it was an attwood and he just said he preferred that be a factory item.
I didn't because it looked fine to me.
It did idle fine but underway it would sometimes "choke out" or at least choke down.
After fuel treatments and other things I stopped at a local boat mechanic and he told me it didn't sound like carbs, he thought it was a fuel line problem.
I bought the factory fuel line and NEVER a problem since.
Don't know about yours but that was my experience.
#6 Post by lakerunner » Thu May 30, 2013 8:26 pm
Check water pressure, your pump could be going
