What brand of fuel tank are you using?
Posted: Mon Jun 03, 2013 5:41 am
by wijames
I need a new fuel tank in the 9 to 12 Gallon range but all of the tanks I am seeing have really bad ratings. Do ant of you have one that you would suggest?
Re: What brand of fuel tank are you using?
Posted: Mon Jun 03, 2013 6:40 am
by lakerunner
I bought a moller 29 gallon.
Posted: Mon Jun 03, 2013 7:40 am
by MH Hawker
I run 2 6 gal mollers, I was impressed on how thick the plastic is.
Posted: Mon Jun 03, 2013 8:02 am
by wijames
MH Hawker wrote:I run 2 6 gal mollers, I was impressed on how thick the plastic is.
I was really surprised at the bad ratings I'm seeing on the Moller 9 and 12 gallon tanks. Everyone says they leak at the gauge and that the new EPA caps don't vent properly. Any thoughts?
Posted: Mon Jun 03, 2013 9:51 am
by lakerunner
Mine isn't portable. I have electric gauge
Posted: Mon Jun 03, 2013 9:56 am
by wijames
lakerunner wrote:Mine isn't portable. I have electric gauge
Did you mount it on the back platform or under deck?
Posted: Mon Jun 03, 2013 12:40 pm
by HandymanHerb
I got the 18 gallon, we had to put spacers under it to raise it over the bottom fence rails as it was a 1/2 inch to small sitting on the floor
Posted: Mon Jun 03, 2013 1:03 pm
by wijames
HandymanHerb wrote:I got the 18 gallon, we had to put spacers under it to raise it over the bottom fence rails as it was a 1/2 inch to small sitting on the floor
I have a huge rear platform so I think I'll just add a 12 on there and I like the idea of a water separator. Thanks for the idea.
Posted: Mon Jun 03, 2013 1:10 pm
by HandymanHerb
Check with what separator you get, mine can't be in direct sunlight for some reason, might vapor lock it, but the instuctions said not to be mounted in sunlight
Posted: Mon Jun 03, 2013 1:14 pm
by redbeard
I also use the Moller tanks a 24 and 12 Gal been happy with them for the most part going on 4 years how.
Posted: Mon Jun 03, 2013 2:14 pm
by BobG
It looks like the Ameri Kart 27 gallon tank the dealer installed in my boat is about to be replaced with a Moeller 40 gallon tank that'll fit in the space I have.
When you boat on Lake Powell, and it's 40 miles between gas stations, you need all the capacity you can get!
Posted: Mon Jun 03, 2013 2:28 pm
by curtiscapk
wijames wrote:I need a new fuel tank in the 9 to 12 Gallon range but all of the tanks I am seeing have really bad ratings. Do ant of you have one that you would suggest?
Port Richey!! your neighbors to Brett (ronburgundy)!!!
WElcome!
Posted: Mon Jun 03, 2013 2:47 pm
by lakerunner
I replaced the factory tank after 12 years
It is under the rear pad
Posted: Tue Jun 04, 2013 12:09 pm
by wijames
WElcome!
Yep, I've spoken to Brett several times on here but have yet to meet him. Looking forward to it.
