Buying spare prop - Questions
Posted: Fri Jun 28, 2013 7:07 am
by bstat1020
Hello, I am sure the old pitch queston has been asked a million times here but if someone could help me with my setup that would be appreciated.
I have a Harris FloteBote 20CX. Mercury 60HP EFI Bigfoot with a 11P prop on it currently. 5500 WOT RPM and 19MPH. I am looking to get some moretop end speed. We cruise alot and dont do a lot of towing watersports. Looking to get to get to 25MPH if possible.
Typical load is wife, 2 small kids, cooler, and typical gear(lifevests, anchor, snad toys etc..)
Any help would be great.
bstat
Re: Buying spare prop - Questions
Posted: Fri Jun 28, 2013 7:42 am
by jimrs
I don't think a prop is going to help you reach your goal. You might want to start looking for a bigger motor first.
Posted: Fri Jun 28, 2013 8:20 am
by cwag911
25 isn't happening with a 60.
Posted: Fri Jun 28, 2013 8:32 am
You'd need to switch over to a 90 or the largest motor allowed on your boat to get 25 mph out of it. A 115 hp motor may be required to get you up to the speed you desire.
The larger motor would make the boat much more seaworthy, and ultimately pleasurable.
Posted: Fri Jun 28, 2013 11:37 am
by yellowk9
You would struggle to get that with a two pontoon boat and a 90 with a full load. I agree you're asking for the impossible with your current motor. I have a 90 on a 20' with two pontoons and 27 is the fastest I've ever gone and that was in a river going downstream with a light load
Posted: Fri Jun 28, 2013 6:44 pm
by killerkernrich
I have a merc 60 4 stroke just me 20 gals fuel bimmi down slight rear wind gps 18mph wot 5000rpm 11pitch thinking to put a 9 pitch on what do you think then??
Posted: Sat Jun 29, 2013 7:22 am
by Bamby
killerkernrich wrote:I have a merc 60 4 stroke just me 20 gals fuel bimmi down slight rear wind gps 18mph wot 5000rpm 11pitch thinking to put a 9 pitch on what do you think then??
I'd think that an 11 P would or should be near perfect for your boat. Did you purchase it new or used? You may be experiencing issues of run-ability such a fuel restriction due to a dirty fuel filter, or maybe spark plugs that are somewhat fouled or need re-gaped or replaced. But anyway in your case I'd check out the maintenance items for being right first before I'd be buying and replacing props on the boat.
Posted: Mon Jul 08, 2013 4:09 pm
by bstat1020
Ok Agreed that 25mph is not realistic. I am still buying a spare prop which is the title of my thread. Any luck with top end speed if I go to a 13p prop?
Posted: Tue Jul 09, 2013 10:08 am
by BobG
I'm going to look for a self-adjusting zero-slip 99.9% efficient prop. That should get my barge up to...hmm...40 MPH with my 115 at 50% throttle. All I have to do is find a good source of unobtanium, to make the prop myself. Oh, and I also will have to coat my toons with a teflon/unobtanium blend to give me zero drag. Shoot, if I had that, I could go 40 on a 10 HP kicker! Perfect!
Posted: Tue Jul 09, 2013 10:21 am
by mippel
BobG wrote:I'm going to look for a self-adjusting zero-slip 99.9% efficient prop. That should get my barge up to...hmm...40 MPH with my 115 at 50% throttle. All I have to do is find a good source of unobtanium, to make the prop myself. Oh, and I also will have to coat my toons with a teflon/unobtanium blend to give me zero drag. Shoot, if I had that, I could go 40 on a 10 HP kicker! Perfect!
But how would you stop?
Posted: Tue Jul 09, 2013 12:47 pm
by BobG
mippel wrote:But how would you stop?
That's the best part! Just like always - put it in reverse! DUH!!!
Posted: Sat Jul 13, 2013 4:54 am
by bassn429
I had a 14 x 12p on my new 60 bf and got 19mph and only 5200 rpm at wot . I switched to a 4 blade prop 13.8 x 10p and now i get out of the hole alot quicker and hit 21mph per gps. And at wot i hit 6100rpm perfect.
