Skinning or Under Skinning
Posted: Wed Jul 10, 2013 3:43 pm
I have a 2004 18' Triton Summit with a 50 HP Johnson 4 stroke. I was putting on new sonar/ GPS today and had to remove the old and route the new transducer. Pre owner had added under skinning to the left and right side of the rear around the transom. Had to remove and replace these panels to rout wires. Not a very good job in cutting the pieces but at least an attempt. This toon will do 20 mph at 5800 rpm now prop is 11 3/8 X 14 Solas alum. Is there any more to gain if I finish under skinning? Is the norm to do the whole bottom or just around the transom? Thanks.
Doug
Doug
