Console location?
mgarvie
Console location?
#1 Post by mgarvie » Fri Aug 02, 2013 11:59 am
Why are most consoles located at the mid point of a boat or slightly back? Wouldn't a more forward placement make for better weight distribution, better view of obstacles in the water, and easier trailering?
Just curious.
Cycleman07
Re: Console location?
#2 Post by Cycleman07 » Fri Aug 02, 2013 12:03 pm
It all depends on so many factors. Motor/ fuel tank size and weight, seating arrangement etc.
#3 Post by margaritaman » Fri Aug 02, 2013 12:09 pm
Some would say it is because it has always been that way! I saw one years ago that had the console up front and thought it would be much easier to load on a trailer because you have a clear view and passengers are in the back making the boat ride level and plane easier. I think manufacturers are afraid to produce something different from what people are accustomed to.
#4 Post by HandymanHerb » Fri Aug 02, 2013 12:10 pm
I moved mine as foward as I could to the side gate and still be able to set a cooler in front of it and allow the gate to fully open
blackberg
#5 Post by blackberg » Fri Aug 02, 2013 12:33 pm
maybe also because of the cables and control sizes, when I was looking it seemed that 18-24' were the most popular lengths of controls, meaning more affordable.
-bb
mgarvie
#6 Post by mgarvie » Fri Aug 02, 2013 2:27 pm
If anyone has moved theirs forward, did you like the difference? Got a picture?
I have noticed lately that mine is sitting pretty low in the back. Seems every year I get more stuff and it all ends up in the back of the boat.
evinrude2stroke
#7 Post by evinrude2stroke » Fri Aug 02, 2013 4:21 pm
Mid point so you can view all sides of the boat... :donno. Plus, being too far up front may put too much weight in the front causing a nose dive... :donno
Dave
blackberg
#8 Post by blackberg » Fri Aug 02, 2013 6:27 pm
evinrude2stroke wrote:Mid point so you can view all sides of the boat... :donno. Plus, being too far up front may put too much weight in the front causing a nose dive... :donno
that too, I moved my 2 trolling batteries upfront, and was nose diving last time out, I am going to move them back this weekend hopefully.
I usually stand when in tight situations and loading, I can usually all around me ok, mine is about the middle.
-bb
#9 Post by Bamaman » Sat Aug 03, 2013 10:00 am
I think their location is due to the other seating on the boat. I'm now seeing consoles going back and forth, front and rear.
Next thing up is seeing a two seat center mounted console on pontoons.
blackberg
#10 Post by blackberg » Sat Aug 03, 2013 10:20 am
Bamaman wrote:I think their location is due to the other seating on the boat. I'm now seeing consoles going back and forth, front and rear.
Mine was orgiginally a center console, with 2 seats.
It's an '86 model.
During the rebuild it went to a right side console. To make the additional seating flow better.
-bb
MPosey519
#11 Post by MPosey519 » Sat Aug 03, 2013 11:02 am
I pushed mine forward a little bit during the rebuild. But not far, was cost prohibitive for throttle/control cables, wiring harness, steering cables.
Michael
Rough River Lake, Kentucky
50 HP 2003 2-stroke Mercury
