wot only 3200 rpm
peedee
wot only 3200 rpm
#1 Post by peedee » Mon Aug 05, 2013 10:58 am
I have a 50HP yamaha 2 stroke with a 11 5/8 X 11G prop on a 20 foot pontoon. I only get 3200 rpm. On the yamaha website in the performance bulletin on a similar boat has a prop of 12-1/4 x 9. Is the difference in the props that different that I would get that much closer to 5500 at WOT, or is there something else not working correctly.
2005 20' Tahoe
50 Yamaha 2 Stroke
MPosey519
Re: wot only 3200 rpm
#2 Post by MPosey519 » Mon Aug 05, 2013 11:01 am
*Beating the dead horse* Carbs?
Michael
Rough River Lake, Kentucky
50 HP 2003 2-stroke Mercury
peedee
#3 Post by peedee » Mon Aug 05, 2013 11:20 am
my brother in law took the cards apart this spring and cleaned them all out. We did have an issue with the emergency enrichment valve. We have to leave it open or it stalls out. So you think the carbs are still clogged? It rides around fine, just can't get the rps up and it is slow anyway with a 50HP on it.
2005 20' Tahoe
50 Yamaha 2 Stroke
MPosey519
#4 Post by MPosey519 » Mon Aug 05, 2013 11:28 am
That's the symptoms mine had before I rebuilt the carbs. Not saying that's it, just what I got
Michael
evinrude2stroke
#5 Post by evinrude2stroke » Mon Aug 05, 2013 12:44 pm
3200 rpm's doesn't sound right. Sounds like a prop issue. I have a 40hp and I get 4500 rpm wot. gets me up to 18 mph which about max for my boat. I'm not exactly sure about them but there is kind of a science to them. Try the search function, there are a lot of threads on prop sizing on here.
Dave
shoundog
#6 Post by shoundog » Tue Aug 06, 2013 9:25 am
peedee, I can only tell you that I saw a big diff in changing my prop. See my post about the 200 rpm rule.
Doug
