Motor Question
Posted: Tue Aug 06, 2013 5:52 pm
by darrenmel
My mom bless her heart… just bought a Crestliner 2085 Sport Classic, it has a mercury 60 EFI and with only me on the boat gets like 16mph GPS !! WHAT THE!?!? does this sound right? I had a tune up done on the motor but no difference. I heard the Bigfoot motor is better for toons? Can we change the prop to a 4 blade? different pitch? LOL
Thanks in advance
Re: Motor Question
Posted: Tue Aug 06, 2013 6:04 pm
by DRock
Sounds maybe a pinch slow, but not too much. What pitch prop are you running now and at what rpm? A 4 blade will generally "bite" better, resist cavition, etc, but are about 1mph slower on top end in my experience. Also make sure the pontoons are clean. Get us the pitch and rpm and we can tell you if you're propped wrong.
Re: Motor Question
Posted: Tue Aug 06, 2013 6:10 pm
by evinrude2stroke
That may be about right. How much weight you have on it (furniture, gear, fuel, humans) makes alot of difference. My 18 footer has a 40hp and I get 18mph with me. the wife and minimal gear.
Re: Motor Question
Posted: Tue Aug 06, 2013 6:47 pm
by darrenmel
DRock wrote:Sounds maybe a pinch slow, but not too much. What pitch prop are you running now and at what rpm? A 4 blade will generally "bite" better, resist cavition, etc, but are about 1mph slower on top end in my experience. Also make sure the pontoons are clean. Get us the pitch and rpm and we can tell you if you're propped wrong.
OK I'll get you the RPM but have no idea on the pitch?? How do you tell??
Re: Motor Question
Posted: Tue Aug 06, 2013 6:51 pm
by darrenmel
evinrude2stroke wrote:That may be about right. How much weight you have on it (furniture, gear, fuel, humans) makes alot of difference. My 18 footer has a 40hp and I get 18mph with me. the wife and minimal gear.
Hmm may be right, I was just me on it have no idea on the weight
Re: Motor Question
Posted: Tue Aug 06, 2013 7:12 pm
by DRock
darrenmel wrote:DRock wrote:Sounds maybe a pinch slow, but not too much. What pitch prop are you running now and at what rpm? A 4 blade will generally "bite" better, resist cavition, etc, but are about 1mph slower on top end in my experience. Also make sure the pontoons are clean. Get us the pitch and rpm and we can tell you if you're propped wrong.
There should be some numbers stamped on the hub of the prop on the outside, or on the inside of the hub(prop would have to come off to read it though).
Re: Motor Question
Posted: Tue Aug 06, 2013 7:15 pm
by darrenmel
DRock wrote:darrenmel wrote:DRock wrote:Sounds maybe a pinch slow, but not too much. What pitch prop are you running now and at what rpm? A 4 blade will generally "bite" better, resist cavition, etc, but are about 1mph slower on top end in my experience. Also make sure the pontoons are clean. Get us the pitch and rpm and we can tell you if you're propped wrong.
Ok awesome I'll look and see Thanks!!
Re: Motor Question
Posted: Tue Aug 06, 2013 7:20 pm
by DRock
Make sure the pontoons are clean with no growths on them as well. Just a little bit of buildup can really slow these things down.
Re: Motor Question
Posted: Wed Aug 07, 2013 5:00 am
by rancherlee
those crestliner pontoons are very heavy well built pontoons but SLOW although 16mph sounds a bit slow too me, the one I've was on would do 18-19mph with a Suzuki DF70 and a 4 people on it (took a ride on one while looking for my pontoon)
Re: Motor Question
Posted: Thu Aug 08, 2013 2:13 am
by ROLAND
just for comparison, under absolute perfect conditions, with me and the wife on board, my yamaha 75 gets us up to approx 23 mph... thats when the lake is smooth as glass...
Re: Motor Question
Posted: Fri Aug 09, 2013 8:46 am
by Thin Ice
Before I re-powered, I had a 60 EFI Bigfoot and i averaged 16-18 MPH. 20 MPH with perfect conditions. I would say you are pretty close, look for unnessesary weight.
