Titan boat lift for Lake of the Ozarks?
GGALVIN
#1 Post by GGALVIN » Mon Oct 14, 2013 2:25 pm
New Titan or used Poly Lift? Dock opens to main lake!
woolznaz
Re: Titan boat lift for Lake of the Ozarks?
#2 Post by woolznaz » Tue Oct 15, 2013 10:57 am
I don't know anything about Titan, which does not mean anything good or bad, I just don't know them. I have had a few Poly Lifts over the years and never had any issues with them, and they had great resale value as well. I think their reputation is about as good as it gets at LOTO.
If you are in rough water, make sure to have it installed with that in mind. I think there are rough water kits or rough water installations vs a more typical installation in a quiet cove. Also, although I never had one, I would get a remote if I was buying another lift. That way you can raise it back up after leaving the dock rather than let it hang there. Then when you get back you can drop it back in the water and drive into the slip. All of that can be done without dropping a passenger off at the dock or picking them up as long as you have the remote.
Good luck!
2007 South Bay 925 Tri-toon
5.7 Volvo I/O
#3 Post by Bryden24shp » Tue Oct 15, 2013 5:40 pm
I don't think I have heard of a Titan lift. I know the PolyLifts reputation is good. Plus parts are readily available. That's the route I would go!
