Transducer placement
Posted: Fri Oct 18, 2013 4:50 pm
by Itsabouttime
My Bennington has the transducer for the built in depth gauge on the left pontoon. There is a flange there that is about seven inches wide. My question is can I mount the transducer for my Hummingbird GPS unit on the same flange without causing any interference between the two transducers. They would be mounted about three to four inches apart.
Re: Transducer placement
Posted: Fri Oct 18, 2013 6:51 pm
by Liquid Asset
I have never mounted 2 next to each other but if they are at the same level I don't see why it would't work .
Posted: Fri Oct 18, 2013 8:58 pm
by badmoonrising
It'll work fine. On my Party Cruiser I did the same thing and never had an issue.
Posted: Fri Oct 18, 2013 9:26 pm
by killerkernrich
my question ...are they interchangable if I switch brands say from Garmin to hummibird??
Posted: Sat Oct 19, 2013 3:45 am
by Drago
I have a Garmin and a Humminbird mounted about 3 feet apart and only get interference when I run both at the same frequency and at the same time. I don't think the transducers are interchangeable - each has proprietary connections.
Posted: Sat Oct 19, 2013 6:11 am
by Itsabouttime
Thanks for the input. While the boat is out of the water I will mount the hummingbird gps depth finder transducer. Only other option is to take it to someone who could weld a mounting flange on the other pontoon. Really don't want to weld on the pontoons.
