Sealant
Posted: Sat Feb 22, 2014 2:31 pm
by ezrollin
What sealant did you use for your thru the transom motor support bolts, will silicon suffice ?
Re: Sealant
Posted: Sat Feb 22, 2014 2:41 pm
by HandymanHerb
Doesn't mater since the bottom of most transoms have a big hole in the bottom to let water in and out, but silicone will help with wood rot around bolts
Re: Sealant
Posted: Sat Feb 22, 2014 2:57 pm
by ezrollin
Yes,now that you mentioned it probably only splash water would be on those bolts. I did treat the bolt holes [5 on each side] holding the transom with a liberal coating of urethane,the bottom ones stay pretty wet.
Re: Sealant
Posted: Mon Feb 24, 2014 6:59 pm
by playcat
I would coat the holes with thin epoxy and let cure completely. ream out the holes if need be, and seal with 3M 4200 polyurethane sealant
Re: Sealant
Posted: Tue Feb 25, 2014 10:57 am
by fergusmj
Just a quick thread hijack. I assume sealant isn't needed for the all aluminum transoms correct?
