Another home made ski tow bar - finally installed!
PlaynDoc
#1 Post by PlaynDoc » Thu Mar 13, 2014 7:58 pm
OK... I've taken the plunge. I like towing tubes and skiers.. My daughter is getting to the age of 'maybe it's time for skiing'.....
I'm tired of using the Y yoke strap with swivel. I'm tired of using the Powerball Tow System.... Both are great devices, but more hassle than having a tow bar.
Here's the plan... Since I have no idea how much it costs to powder coat a ski tow bar, and since my welder guy does all the work at home - with a driveway issue that won't allow me to leave my boat at his house.... I made a PVC mock up/prototype... I called Powder Coating by JLC for estimate on powder coating. I emailed them these pictures. He said, that since it will be exposed to a lot of water, he needs to add some type of special primer, followed by powder coating in my choice of color, should be around $150. I think I'm going with a beige/tan type color, since 1. My wife says so, and 2. Matches some of the striping on the boat graphics.
Sounds good enough. My welder guy will pass on the savings of the material to me. He can get all the tubing/angle iron stuff from his workplace, at wholesale pricing. We're going with 1 1/2" tubing with 3/16" wall. The base will be 2" angle iron... The tow bar will be mounted to the same cross members that the engine pod is mounted, using heavy strength bolts....
Sound strong enough?
Anyway, here's the photos of the initial prototype... I'm going to add some additional braces that go from the slanted/angled tube, to the vertical rear piece... They're not on at time of photos. I'm also going higher with the angled/rear supports.
I'll update this when the welder finishes.... Of course, ignore the wooden and the grey pvc support bars....
The Powerball Tow System will be for sale when this tow bar is completed.... I think...
rancherlee
Re: Another home made ski tow bar
#2 Post by rancherlee » Fri Mar 14, 2014 6:30 am
PlaynDoc wrote:OK... I've taken the plunge. I like towing tubes and skiers.. My daughter is getting to the age of 'maybe it's time for skiing'.....
Here's the plan... Since I have no idea how much it costs to powder coat a ski tow bar, and since my welder guy does all the work at home - with a driveway issue that won't allow me to leave my boat at his house.... I made a PVC mock up/prototype... I called the closest place for powder coating. I emailed them these pictures. He said, that since it will be exposed to a lot of water, he needs to add some type of special primer, followed by powder coating in my choice of color, should be around $150. I think I'm going with a beige/tan type color, since 1. My wife says so, and 2. Matches some of the striping on the boat graphics.
looks good to me, Mine is built out of 2x2x.125 square stock and had been abused with 4 person tubes and pulling other boats without a single complaint. Only difference on mine is the angled bars form the main loop and the uprights are the support so the tow point ends up being back a bit farther to keep the rope off the outboard easier when the line is slack.
#3 Post by curtiscapk » Fri Mar 14, 2014 7:11 am
Awesome!
#4 Post by Bamaman » Fri Mar 14, 2014 11:42 am
Looks good, Doc. Have you thought about having the tow bar welded on top of a piece of flat steel instead of using angle? I would think walking around the bar with angle iron might result in some stubbed toes.
Don't forget that you've got to have a stainless steel ski eye in the middle of the top cross piece to tie the ski rope to. The Big O in Fayetteville, NC carries them--$35 to $69.
PlaynDoc
#5 Post by PlaynDoc » Fri Mar 14, 2014 4:05 pm
Bamaman wrote:Looks good, Doc. Have you thought about having the tow bar welded on top of a piece of flat steel instead of using angle? I would think walking around the bar with angle iron might result in some stubbed toes.
Using angle for strength. The vertical portion (rear most) of the tow bar must extend beyond the rear of the boat, because when the rear sun deck opened, it needs the clearance. The possible force on flexing of flat steel beyond the boat edge will place and rely all force onto the bolts only. The angle prevents any chance at flexion. All edges will be rounded, to reduce the pain factor. It might be a bit overkill, but I want this thing to never cause me heartache, or the evil eye from the wife, to spend more to replace it. As far as walking around the bar, there's never anyone walking around it.... however, I can see, on the rare occasion that I need to get to the rear cleat from inside the boat, i can see where it will be in the way.
A ski eye will be made, and welded as part of the bar. At the area of the ski post/eye, there will be a layer of double thickness tube wall welded on. A hole will be drilled through all '4' layers, to weld the post in place. All this will be done before powder coating, so it looks like it belongs...
PlaynDoc
#6 Post by PlaynDoc » Tue Apr 01, 2014 6:57 am
Time to post some update pics...
Here are the 'dry fit' pics... merely tack welded.... hoping the final welds will be finished, edges rounded to a finished look, and ready to be picked up today... Then, just need high strength bolts... Then, perform the dreaded drilling through the deck... can't get that wrong. must be right the first time. After bolt-holes drilled... then, off to the powder coating....
Image[/URL]
#7 Post by curtiscapk » Tue Apr 01, 2014 7:56 am
:nana :nana :nana :nana :nana Looks great!
hootowlhollow
#8 Post by hootowlhollow » Tue Apr 01, 2014 8:12 am
looks awesome. Bet you could pull tree stumps with that thing!
2013 Bennington 24SSRL
150 hp Yamaha
1 Wife and 3 Boys
tuned
#9 Post by tuned » Wed Apr 02, 2014 3:05 am
hootowlhollow wrote:looks awesome. Bet you could pull tree stumps with that thing!
He gonna git on dat Swamp Logger show!
PlaynDoc
#10 Post by PlaynDoc » Fri Apr 25, 2014 3:49 pm
Here is the final installation...
Will put it to the test next week sometime...... as soon as i can get to the lake again.... with tube, and people to ride....
Let the stump pullin' commence!
r&s20
Re: Another home made ski tow bar - finally installed!
#11 Post by r&s20 » Fri Apr 25, 2014 6:35 pm
very nice, playndoc makes me wish mine had room for one. congrats
fish and cruise
I am not ADULT SUPERVISION !
#12 Post by curtiscapk » Sun Apr 27, 2014 7:31 pm
looks great! I recognize an older version!
tuned
#13 Post by tuned » Sun Apr 27, 2014 11:06 pm
Awww. He even got a glint of sunshine in the finish. :thumbsup
justrfb
#14 Post by justrfb » Mon Apr 28, 2014 3:44 am
Nice... Good Job and good for you! :alright
Sincerely,
Rich
Rich and Annemarie Bias
2007 Merc 75 4 Stroke
2006 Honda Pilot
