Isolated Trolling Motor Battery?
NonHyphenAmerican
#1 Post by NonHyphenAmerican » Wed Apr 16, 2014 6:22 pm
As I'm learning about my toon, I came across something I'd probably like to change.
I've seen mention here of battery switches for multiple batteries.
I used to be familiar with them for fire trucks, ambulances, etc.
The trolling motor on my toon is hooked to an isolated battery under the drivers console that is not charged by the Yamaha motor.
For starters, I could hook it to a charger, or bring it home from the marina and charge it.
However, what would be the best way wire it so that the outboard charges it?
Ideas?
PlaynDoc
Re: Isolated Trolling Motor Battery?
#2 Post by PlaynDoc » Thu Apr 17, 2014 6:30 am
i dunno how you'd wire that... because.... well, just because i have minimal boat/electrical skills.. and, I've not heard of charging a trolling battery from engine... i THINK it's because of the S L O W rate in which the motor recharges the battery.... would be kinda comparable to a 3 amp charger.. would take about 15 hours or so to charge a trolling battery...
BobG
#3 Post by BobG » Thu Apr 17, 2014 9:35 am
Use a blue-sea add-a-battery. It will charge it while you're driving around.
Rascal
#4 Post by Rascal » Thu Apr 17, 2014 4:12 pm
BobG wrote:Use a blue-sea add-a-battery. It will charge it while you're driving around.
X2,
I have the Blue Sea Add A Battery kit charging two batteries under my helm and the engine battery in the rear. My engine gives 40 amps to the battery that needs it. The engine gives out the full 40 amps after about 1000 rpm's. It will charge the low battery in a short period. I have not used a battery charger in the last three months since installing the Blue Sea's kit on my pontoon. The only negative was installing the 4 awg battery cables from the helm batteries to the rear battery and cost of the cables. But, well worth it (IMHO).
I had the same system on my Sea Cat and did not charge the batteries in a year since the system was installed. The guy I sold the boat to has not used his battery charger on the Sea Cat ever (six months).
Rascal
Fishing Year Round SW Florida
Premier 22' 2012 Cast A Way
115 hp Honda, 15.5 x 13 prop
Sea Star Power Steering
Day Enclosure
Loan Star Anchor Winch
Fixed Mount ipad Air for
babock
#5 Post by babock » Fri Apr 18, 2014 11:39 am
You don't need the whole add a battery kit. You just need the ACR which can be bought separately.
65A version
http://www.bluesea.com/products/7601/m- ... 24V_DC_65A
120A version
http://www.bluesea.com/products/7610/SI ... 4V_DC_120A
Mercury 90 4 stroke
bobalong
#6 Post by bobalong » Fri Apr 18, 2014 12:19 pm
I have looked at some of the "on boat" charging systems as well, but we do a lot of fishing when we go out, and although we may be out fishing for 8 or more hours some days, the actual running time of the main engine may be an hour at most. I am considering a solar panel, as I believe I would get much more charging time from that, than I would using the main motor.
2011 Sweetwater 206F Sunrise
2011 60 HP Evinrude Etec
Humminbird 798SiHd
Boating on Moose, Pigeon, Lac St. Anne and Sask Landing
