Hand controlled Bow mount controlled Trolling Motor? Mounted
Posted: Mon Apr 28, 2014 8:47 pm
by Hawk_308
Im looking at this Trolling motor
http://www.amazon.com/gp/product/B003CK ... d_i=507846
I dont want one that stores on deck because one I would have to modify the door and I dont want it in the way of my disabled son since if we go to town on the boat we will have his wheel chair on board. And I cant find any others that store vertical . Minn Kota is out for personal reasons Had 2 of them fail during tournaments
Im just worried that to get the varimax in the water Ill have to have the head almost on the floor which will be a PITA to operate . Im planing on mounting it on the port side just inside of the of where the foot rest rail is . If it is to short I wondered how hard it would be to cut it and extended it between the mount and head .
Re: Hand controlled Bow mount controlled Trolling Motor ?
Posted: Wed Apr 30, 2014 7:45 am
by wijames
Hawk_308 wrote:Im looking at this Trolling motor
I have one on my toon and love it. I mounted it sideways on the right side but had to remove part of my side rail in the front. It works great. Here is a picture of how it looks for you.
Posted: Wed Apr 30, 2014 3:23 pm
by Hawk_308
Thanks , The one Im going to order is going to have the simple pontoon mount so it is going to just slide up and down . Is yours a 50" , does it sit a comfortable height ? How does it pull you along ?
Posted: Wed Apr 30, 2014 5:24 pm
by saltydawg2
I have one mounted at the front, just to the right of the bump bars, on my 20' Sweetwater. I bolted a heavy, aluminum angle to the front, and then bolted 5/4 treated decking to that; just large enough to be able to bolt the transom on. I turned the head around 180 degrees so blades and handles would face the back. Pontoons are only 19", so only needed 42" shaft on troller. Tried it out the other day, and it worked great. 55# thrust moved it more quickly than needed at higher speed, but it was mostly calm lake waters. I had a little space between the console and rail, so I store it there, and lock it, out of the way. Want picture, let me know.
Posted: Thu May 01, 2014 6:47 am
by wijames
Hawk_308 wrote:Thanks , The one Im going to order is going to have the simple pontoon mount so it is going to just slide up and down . Is yours a 50" , does it sit a comfortable height ? How does it pull you along ?
Yes mine is the 50" and it does quite nice even in a strong wind. The height is great and easy to control without being in the way when fishing
Posted: Thu May 01, 2014 3:34 pm
by saltydawg2
Here are the photos I mentioned.
Posted: Thu May 01, 2014 7:45 pm
by Hawk_308
Thanks to both of yall , I pulled the trigger tonight and it was 58 bucks cheaper. I was going to get the reman one for 361 but for 38 bucks more I got it from amazon so Ill have it monday , I was hoping they had it at the local amazon wharehouse if they did it would be here tommorow at lunch .Love me some Amazon prime .
Posted: Fri May 02, 2014 6:46 pm
by Hawk_308
Well picked up 2 group 27s today , now only if brown santa will get into gear . I guess Ill build the boxes for them . Im thinking about tring something like this for charging
http://www.dualpro.com/media/pdf/charge ... %20run.pdf
Posted: Tue May 06, 2014 5:05 pm
by Hawk_308
The MotorGuide VariMax 75 lbs thrust 24 volt 50" pontoon mount is Mounted , still havnt done the battery box or wiring yet but here is was I done this evening .
From the seat
UP Periscope
I guess this will hold it if the factory 2 locks fail , it has the squeeze slider and the twist lock
