Merc 50 engine won't stay running
mabrown
#1 Post by mabrown » Thu May 01, 2014 9:17 am
Hi all,
I'm attempting to start my 2005 Merc 50 4 stroke and it will run for about 2-5 seconds then just cut out. Does anyone have any suggestions as to what could be the problem?
Thanks
M.A.Brown
USN Vet
Re: Merc 50 engine won't stay running
#2 Post by curtiscapk » Thu May 01, 2014 9:34 am
1. Is your vent opened on your tank? 2. Clogged fuel filter? 3. Dirty Carbs?
NonHyphenAmerican
#3 Post by NonHyphenAmerican » Thu May 01, 2014 4:59 pm
Gunked up gas?
LongLakeLegacy
#4 Post by LongLakeLegacy » Thu May 01, 2014 5:29 pm
Did you put sea foam or stabilizer through it in the fall?
2013 Manitou Legacy 25 Shp
250HP Yamaha SHO 4 Stroke
2012 F350 Lariat Crew Cab Diesel
dunny961
#5 Post by dunny961 » Sun May 04, 2014 10:08 am
Not sure if this will help but my 90 Merc had a bad fuel level sensor in the fuel pump housing that made it flood out. It mostly would just run a few seconds and die. If you could ever give it some throttle before it died, it would run at wot. But it would never idle.
90 Mercury Fourstroke
Capt Sully
#6 Post by Capt Sully » Sun May 04, 2014 12:01 pm
:lol: :lol: :lol: All the above, I would check :lol: :lol: :lol:
2012 Xcurison X23C
Yamaha 90 hp 4 stroke
Maritime mobile KD4LZL
Lake Allatoona, NW Ga.
FVC USCG Auxiliary
Vietnam 66 / 67
