2014 Merc 115 RPM's too high!?
Dusto
#1 Post by Dusto » Wed May 14, 2014 6:41 am
Brand new 2014 Mercury 115 four stroke. Tachometer goes to 7000 rpms. When I take the toon to WOT it is reading well over 7000rpm’s. I would guess 7500rpm’s or so.... I know it shoudl be between 5800-6400 rpms.
It goes into the dealer next week to be looked at. I am thinking prop issue or tachometer issue? Thoughts?
2014 HF Cruiser 200 tritoon, performance package PLUS, 115hp efi Merc 4 stroke
top speed = 33.5mph GPS
Mercury Spitfire 13.8x13 prop
Re: 2014 Merc 115 RPM's too high!?
#2 Post by curtiscapk » Wed May 14, 2014 6:47 am
I bet the tach is set to the wrong pole in the back. (range selector in the pic \ c = # of cylinders)
smoker62
#3 Post by smoker62 » Wed May 14, 2014 7:46 am
Will hit the rev limiter if its over revving.
GXPWeasel
#4 Post by GXPWeasel » Wed May 14, 2014 10:37 am
I'm with Curtiscapk.
I'd bet the tach is setup incorrectly, or the tach isn't adjusted correctly.
