Bottom Paint
itechteam
Bottom Paint
#1 Post by itechteam » Wed May 21, 2014 5:08 pm
I just bought a 2008 Avalon tritoon, I live on salt water so I am thinking about having the toons painted. What type of paint and how do you do it? I want to be educated before I start talking to people to do it for me.
Thanks,
2008 Avalon 24' Paradise, with 225HO Evinrude ETEC
Gonefishing
Re: Bottom Paint
#2 Post by Gonefishing » Wed May 21, 2014 6:09 pm
Whatever paint u use just make sure you use a primer and that the paint does not have copper in it. Make sure you get a primer for aluminum.
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
itechteam
Re: Bottom Paint
#3 Post by itechteam » Wed May 21, 2014 6:32 pm
is the general consensus to paint when boating in saltwater?
Re: Bottom Paint
#4 Post by badmoonrising » Wed May 21, 2014 9:58 pm
Yes, clean, primer and bottom paint ALWAYS in saltwater. I boat in the Chesapeake which can range from a salty as teh ocean to somewhat feesh and when I owned my Party Cruiser (kept in a slip) it was bottom painted from day 1.
I did 2 coats primer and 3 coats Interlux paint...make SURE you use paint made for aluminum hulls. If you use copper on an aluminum hull, you will get absolutely severe corrosion quickly...enough to make pin holes in a single season. :shock:
I've seen boats damaged by the wrong paint in this forum as well as in my experience with the local marinas, some who do it wrong :shock: and right.
itechteam
Re: Bottom Paint
#5 Post by itechteam » Thu May 22, 2014 4:25 am
My boat is lift stored, but I think I will still bottom paint it.
Re: Bottom Paint
#6 Post by badmoonrising » Thu May 22, 2014 9:49 am
Good idea because pontoon boat lifts generally are carpeted, which holds water. Better paint to insulate the hull from the wet padding.
itechteam
Re: Bottom Paint
#7 Post by itechteam » Thu May 22, 2014 9:51 am
yeah when I had the bunks redone for the tritoon I had them put trex on top of the salt treated lumber, no carpet.
